#281 |
It'll be aight
Super Cool Since: Dec 2011
Locale: Tulsa
Postings: 819
Well, I don't have the opportunity to ride all day everyday for weeks on end like that. Im 26, school loans, mortgage, have a stay at home wife with a 2 year old and one on the way. The most free time I can muster is the occasional Saturday morning ride down to the lake dam for some ATV trails. It'll get better as the kids get older and they can come with me!
![]() 2009 KLR Black Debadged Caribou 40L Cases, Cee Bailey Wind Shield , EM Doo, T-bob, .22 Mod, Drilled Slide, Pilot @ 2 turns, Low Buck Exh. Mod., De-Snorkeled, L-Mod., HT Skid Plate/Center Stand, 16T, YZ125 Fender Mod. |
#282 | |
Super Cool Since: May 2007
Locale: Cheyenne Wyoming
Postings: 1,284
Took 35 years in-between to clear the mortgage, have and raise the two kids and get them through college and retire from the profession before I got back the time to do long rides. Not that I didn't have a wonderful time raising the kids and practicing the profession - but there is only so much time in a life and once parenting enters the picture, a guy has to use the time he has wisely. I didn't mind at all waiting for the ride to Alaska - life has always been an adventure! |
#283 | |
It'll be aight
Locale: Tulsa
Postings: 819
#284 |
Super Cool Since: Apr 2011
Locale: Redondo Beach, CA
Postings: 629
I put some YZ425 ones on mine. Cost was about $15! The pin is a different size so you have to shim the Kawi pin or drill out the mounting holes & shorten the YZ pin
![]() The Motech ones with the removeable rubber pads like Wyman has are nice. more spendy though. ![]() |
#285 |
Postings: 1,284
The DR650 pegs and springs were a direct fit for my '06; not sure if they work on the '08s and up, but cost was under $40 at the Suzuki dealer when I bought mine.
#286 | |
Super Cool Since: Sep 2011
Locale: NorCal
Postings: 391
#287 |
Locale: NorCal
Postings: 391
1. $20 Throttle lock (pictured)
2. 16 Tooth front sprocket 3. MadStad Engineering 20" Adventure shield $269 4. Doohickey 5. Front Suspension $300 6. 688 Kit (installed price at about $600) 7. Rear Suspension (Ricor Model C with 400lbs Eibach spring $550) 8. Heated Grips (under grip strips) $44.95 (about $50 with a relay and wiring) 9. Sargent Seat $3691. $20 Throttle lock (pictured) 10. Happy Trails Tetons & SU Racks $679 #10 So what is an adventure touring klr without luggage??? The top 10 farkles then must include some sort of luggage! After going back and forth and considering many options, I finally landed on a set of Happy Trials 7.5” Tetons Powder Coated pre mounted set that was on sale in combination with the SU racks. I went with this setup over many other choices mainly because of size and simplicity. Many of the other options including the Caribou setup were just too wide, in fact wider than the handlebars and that just seemed like a big no-no to me at the time. Also the Caribou system has a horizontal crossbar that connects below the rear fender and is in my opinion somewhat less than cool looking. The SU rack meanwhile tucks in nicely behind the fender, this was in important consideration since I knew I wanted to get rid of some of the black plastic associated with stock license plate frame. I received my set and I was very satisfied with the build quality of both the racks and the boxes. The bike has been down a couple of times lightly in dirt and nothing has tweaked yet. The seals also seem to keep out dust. I am also happy with the minimalist adventure motorcycle look. I also ended up going with the HT top box but I am not as happy with that decision/value as I am with the Tetons so those did not make my top 10. So here is a unique angle of the Happy Trails Tetons! ;) ![]() photo by 916Glass, on Flickr |
#288 |
2003 KLR 650
Locale: Sacramento, Ca, USA
Postings: 37
I kind of thought we would need the rubber for vibration dampening? Has anyone tried to "sipe" the original rubber pegs? In the mean time, I was able to add my 450 lbs eibach spring and bumped the dial on the bottom of the shock from 1 to 4. Haven't touched the per-load yet but the spring seems much stiffer. Almost zero sag without a rider.
#289 |
Postings: 1,284
Your riding boots will provide all the vibration control you need. What you REALLY need down there is a no-slip connection between your boots and your bike. First time your foot slips off a peg and gets sucked under that metal pannier box, you are going to be cursing that rubber peg (and the cast on your tibia) . . .
#290 | |
Locale: NorCal
Postings: 391
#291 |
Locale: NorCal
Postings: 391
Dunlop 606s on order
Aerostich heated vest on order Kermit chair on order spare spark plug and brake pads packed, oil & filter changed, new uni installed. Is it time to go yet? ![]() Any consensus out there on what the max oil change interval is? What would you stretch it to on this trip considering most of this will be easy cruising speed with not much stop & go and most likely very moderate temps. I am running Mobile 15-50 synthetic and the Kawi oil filter. Thanks! ![]() |
#292 | |
Postings: 1,284
If they still fit, I think I paid $38 for the set at the local Suzuki dealer, brand new in the bag. Back then then part numbers were: 43550-44B10-019, footrest, right; 43560-44B10-019, footrest, left; and 2 springs, 0944-15008. |
#293 | |
Postings: 1,284
Turned out that I was hitting that 3,000 mile mark near enough to a WalMart each time that all I had to do was pull in, buy three quarts of oil, roll around to the automotive bay and the guys would lend me a drain pan and recycle the old oil while they asked about the bike, the trip, the usual . . . ![]() |
#294 |
Locale: NorCal
Postings: 391
Happy independence day!
We got out this morning for some "glamour shots" prior to the trip. The KLRs will never new this clean again after the Dalton/Dempster! :bang head: ![]() _MG_5516 by 916Glass, on Flickr |
#296 |
Let's Ride!
Super Cool Since: Apr 2012
Locale: Taylor, Texas
Postings: 141
Awesome photos! Lucky Bastards!
![]() You just don't know how I WISH I was tagging along with y'all! ![]() I see you didn't put on the new front fender ? The vinyl trick didn't work for ya? Tim
Tim Stable: 2012 KLR 650~Blk 2012 C14 Concours~Blk 2001 KLR 650~Silver/Grn 112 miles 2012 Suzuki Boulevard S40 |
#297 |
Locale: NorCal
Postings: 391
I went riding instead... can you blame me? :love it:
I still have 9 days to make it happen... ![]() |
| Thread Tools | |
| Display Modes | |
