KLR650.NET Forums - Your Kawasaki KLR650 Resource! - The Original KLR650 Forum!
Go Back   KLR650.NET Forums - Your Kawasaki KLR650 Resource! - The Original KLR650 Forum! > KLR650.NET - Kawasaki KLR650 Forums > 2008 through 2013 KLR650 Discussion
2008 through 2013 KLR650 Discussion The new, industry dominating second generation KLR650
Old 09-13-2007, 05:09 PM   #21
John0270
John0270's Avatar
Super Cool Since: Jul 2007
Locale: Sask, Canada
Postings: 1,320
Default Re: I can't decide on tires :(
Thats it I am going with the 606's. Are the stock tubes good enough?
John0270 is offline   Reply With Quote
Old 09-13-2007, 05:19 PM   #22
Tagati
Tagati's Avatar
Super Cool Since: Jun 2007
Locale: Townsville, Australia
Postings: 241
I used heavy duty ones but i see no reason why you couldn't use the stock ones.
Just to add to what the 606's are like on the street the only way i can get them to lose grip on the dry is by giving it heaps through a sharp turn and being really hard on the change from 1st to 2nd. the read steps out just a tiny bit. silly but fun
Tagati is offline   Reply With Quote
Old 09-13-2007, 10:05 PM   #23
jpwilhelm
jpwilhelm's Avatar
Locale: Dearborn MI, USA
Postings: 86
Originally Posted by JSPEED View Post
How do you like your pipe. It looks awsome, In my opinion it is the only pipe that looks like it was made for the KLR. Is it loud?
The only problem had with the pipe was the bolt fell out that holds the spark arrester in. the SA did not fall out but it makes noise. I put a screw in to hold it but stll makes a rattle noise. I failed the sound check at last weeks DS ride here in MI. the reader said 100.5 db.
As far as the tires I have had no problem on the street other than a little swim at high speed on a rain grooved highway. These will be the only tires I get, unless I know I will be doing a lot of highway miles on a trip. I was thinking the Mefos or TKC's for that .
08 KLR650 all black
http://www.myspace.com/jpwilhelm
jpwilhelm is offline   Reply With Quote
Old 09-14-2007, 09:06 AM   #24
John0270
John0270's Avatar
Postings: 1,320
What sizes are you running with the 606's and are there any clearance issues?
At american motorcycle tire they list a 130/80 17, Im not sure what these numbers mean but if its the same as car tires its going to be a bit wider?
Old 09-14-2007, 09:19 AM   #25
Ridge
power to the pedal
Ridge's Avatar
Super Cool Since: Sep 2007
Locale: Burlington, NC
Postings: 1,337
130= section width. 130mm across the tread
80 = section height (aspect ratio) or 80% of 130mm = 104mm high
17 = Wheel diameter
Ridge is offline   Reply With Quote
Old 09-14-2007, 09:20 AM   #26
jpwilhelm
jpwilhelm's Avatar
Postings: 86
I have the 130/90-17 rear on it. I have no clearance issues.
08 KLR650 all black
Old 09-15-2007, 01:09 PM   #27
Xtreme
Locale: Arkansas
Postings: 2,524
Well, those D606's look awesome and I will be fitting those in that size next time around, just what I need. Below are a couple of photos of the stock sized C6006's a currently running. They are very good indeed but those D606 absolutley rock!
Schnitz Racing 685 & 705 Big Bore Kits
http://www.schnitzracing.com
Xtreme is offline   Reply With Quote
vB code is On
Tires tires tires! layfju 2008 through 2013 KLR650 Discussion 11 09-06-2007 12:05 AM
Road tires !! tbird07 Gear Discussion +GPS 7 04-25-2007 10:39 AM
Street tires: Am I selling out? imported_FEF KLR650 Main Discussion 31 01-06-2007 10:57 PM
Tires Flyingpackman Gear Discussion +GPS 16 06-17-2005 02:48 PM
Newbie, many questions: tires & other improvements zimbop KLR650 Main Discussion 1 10-31-2004 11:39 PM
Powered by vBulletin® Version 3.6.10
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
