Custom Search
09 with 2000 miles has low Doo spring tension? - KLR650.NET - Your Kawasaki KLR650 Resource! - The Original KLR650 Forum!
Go Back   KLR650.NET - Your Kawasaki KLR650 Resource! - The Original KLR650 Forum! > KLR650.NET - Official Vendor Area > Eagle Mfg & Eng
[REMOVE ADVERTISEMENT] 2008/2009 KLR650 Review
Old 07-26-2009, 10:18 AM   #1
us3
us3's Avatar
us3 is on a distinguished road
Default 09 with 2000 miles has low Doo spring tension?
Hi Mike, this is Matt, we meet last month at your shop. (Black 09 with tick)
I just did a 2000 mile maintenance which I also checked the valve clearance and the Doo spring tension. The valves were right in the middle of the spec but the Doo spring tension seemed low to me. (not sure what it's supposed to be though). There was still a little spring left in it but it didn't seem that tight.
I thought I read that I may be able to just put a smaller spring in for now and then put your kit on at a later time. Please let me know what you think, I'd like to get a smaller spring for now and then put your kit on at the next maintenance or rebuild.
I also had a couple questions about your other parts but we can hopefully talk about those soon.
Have a great day and please let me know what you think I should do with my Doo spring.
Matt
us3 is offline   Reply With Quote
Old 07-27-2009, 10:35 AM   #2
us3
us3's Avatar
Default Re: 09 with 2000 miles has low Doo spring tension?
Hi again Mike
After thinking about it, I figured I should just complete the upgrade if I'm going to be in there again.
Could you please give me the info for purchasing and installing your Doo kit? I can stop by any afternoon and pick it up from you.
Anyone locally have the special tools needed for the install?
Thanks Mike and anyone else who could help with the special tools.
Matt
Old 07-27-2009, 10:36 PM   #3
Eaglemike
Level 3 Moderator
Eaglemike has much to be proud ofEaglemike has much to be proud ofEaglemike has much to be proud ofEaglemike has much to be proud ofEaglemike has much to be proud ofEaglemike has much to be proud ofEaglemike has much to be proud ofEaglemike has much to be proud of
Matt,
Just give me a call. You can borrow some of the tools, or wait for a tech day in the area.
all the best,
Mike
Eagle Mfg & Eng since 1990 - Insist on genuine Eagle parts!
Call me six19 261 1281 or email me for parts.
Cary Aspy -the real klr650 guru. RIP my brother, I miss you.
Be your own KLR650 GURU!
New tech day August 21, 2010 thread in California forum
Eaglemike is online now   Reply With Quote
Old 07-27-2009, 11:35 PM   #4
us3
us3's Avatar
Originally Posted by Eaglemike View Post
Matt,
all the best,
Mike
Sounds good, thanks Mike!
I'll give you a call tomorrow.
Matt
Old 08-08-2009, 03:16 PM   #5
us3
us3's Avatar
Here is my stock spring at 2844 miles. It had a little spring left but it collapsed to nothing when I loosened the adjusting bolt today. It could have been out of adjustment by 3750 miles because I just adjusted it at 2000 miles..
Mike is a Great Guy and set me up 100% to complete this job quickly and easily. I'll post again with feedback for him but I wanted to get this pic of a 09 with no spring left @ under 3000 miles.
Thanks Mike!!
Matt
Old 11-06-2009, 12:40 PM   #6
GPS Man
GPS Man's Avatar
GPS Man is on a distinguished road
Well, that's it... I am going to be ordering the parts for my 2009 ASAP!
You would think that Kawasaki would fix this know issue.......???????
GPS Man is offline   Reply With Quote
Old 11-12-2009, 12:20 PM   #7
rustynut
rustynut's Avatar
rustynut is on a distinguished road
here is mine with 600 miles 09
http://www.klr650.net/forums/showthr...ghlight=lookie
Thanks Mike
"Spending money on things I don't need, to impress others I don't know."
rustynut is offline   Reply With Quote
Old 11-12-2009, 12:40 PM   #8
Watt-man
Powertrain Nerd
Watt-man's Avatar
Watt-man is on a distinguished road
This WAS their fix. Earlier systems were known to break the doo and/or spring (as well as simply fail to adjust) and Kawasaki's "fix" in 2008 was to set spring tension near zero from the factory.
At first blush, it seemed that this actually stopped the spring failures, but we've seen a number of them in the new bikes.
Agreed, the proper fix is to buy a good-fitting doo from Mike and spring with proper tension! My vote always goes to the torsion spring, but the extension spring works too as long as you're willing to go in every 30K miles and throw in a smaller spring.
Watt-man
'04 KLR650, 56,000 Miles
'09 KLX250, 5,000 Miles
'08 Versys, 17,000 Miles
... all with Thermo-Bobs, of course!
www.xanga.com/watt_man
Ride it like you own it...
Watt-man is online now   Reply With Quote
vB code is On
Powered by vBulletin® Version 3.6.10
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
