Draining the tank.... - KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum!
Go Back   KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum! > KLR650 Discussion Forums > KLR650 Maintenance, Modifications & Technical
KLR650 Maintenance, Modifications & Technical Wrenching and mods - KLR650 Technical discussion only!
Old 09-05-2017, 06:14 PM   #1
tomm9050
Super Cool Since: Aug 2016
Locale: So Cal
Postings: 40
tomm9050 is on a distinguished road
Default Draining the tank....
I'm trying to drain my tank (2015). Attached a long hose to the petcock fuel line, turned on the tap and nothing happened. normal and reserve settings? Open the gas cap, still no flow. What's the procedure? How do you circumvent the vacuum? Thanks
tomm9050 is offline   Reply With Quote
Old 09-05-2017, 06:39 PM   #2
Postings: 18,456
Default Re: Draining the tank....
Petcock requires vacuum to operate. Install a temp vacuum line to the petcock. Apply vacuum with your mouth. Fuel will begin to drain. I then grab a set of hemostats and clamp the vacuum hose. Tank will continue to drain. If I need faster drainage I'll take a larger clear line and insert in thru the fuel inlet cap. Apply suction (not with my mouth lol) and gravity drain the tank. Use the petcock for the last bit. Be sure and once fuel level stops while on resv lift the tank and tip to the left. This will drain fuel remaining on the right side of the tank over to the left side. Petcock will then drain this remaining bit out. This is also known as the double secret resv fuel all KLR's are equipped with. I've gotten 9 to 11 additional miles using it.
Chuck B is online now   Reply With Quote
Old 09-05-2017, 11:14 PM   #3
tomm9050
Locale: So Cal
Postings: 40
Thanks! Worked perfectly.
Old 09-13-2017, 08:04 AM   #4
Stich
Super Cool Since: Jun 2014
Locale: Colorado Springs
Postings: 206
Stich is on a distinguished road
I'm so glad I put a manual petcock on my tank. I also religiously turn it on and off when I ride and park.
Stich is offline   Reply With Quote
draining, tank
IMS Tank install question/help madcopp94 KLR650 First Generation 16 08-17-2016 01:21 PM
Bike won't start after IMS tank install and valve shim job tReznr KLR650 Maintenance, Modifications & Technical 10 05-25-2015 06:48 PM
Fuel tank dilemma: Draining without power Dan Diego KLR650 Maintenance, Modifications & Technical 14 04-08-2015 11:52 AM
WTT Gen1 NIB IMS 6.6gal Black Tank for Engine Tank Crash Bar denbrewer Classifieds 1 03-23-2015 06:58 AM
IMS 10 Gallon Tank Review Targan KLR650 Second Generation 37 03-21-2015 06:26 PM
