Old 07-28-2012, 09:22 AM   #1
not crazy
Super Cool Since: May 2012
Locale: terrell tx
Postings: 42
Default bearing removal problem
it looks like the spacer is going to make removal of the back bearing problematic. i have a clymer and see what theyre saying to do, but i dont see it happenin. any tips?
not crazy is offline   Reply With Quote
Old 07-28-2012, 10:27 AM   #2
Locale: Flagstaff, Az
Postings: 7,416
Default Re: bearing removal problem
I'll wager you are referring to some bearing on a KLR?
Flagstaff, Az
Old 08-04-2012, 08:49 AM   #3
klrBill
klrBill's Avatar
Postings: 717
The spacer slides around enough to facilitate getting your drift through to tap from the other side. Warming the hub with a heat gun makes the job a lot easier. make sure you remove the clip on one side, and reinstall the new bearing and spacer in the right order.
"Better is often the enemy of Good Enough"
klrBill is offline   Reply With Quote
Old 08-04-2012, 09:00 AM   #4
K7NUT
Dual Sport Fanatic
K7NUT's Avatar
Locale: Tygh Valley,Or.
Postings: 1,748
I'm not sure what he was referring to either chuck?
But it's interesting!?
"If you choose not to decide, you still have made a choice".
"Those who know what's best for us, must rise and save us from ourselves"
'87 KLR 650
'00 Voyager XII
K7NUT is offline   Reply With Quote
Old 08-04-2012, 09:06 AM   #5
Postings: 8,777
i use bearing ID specific collets and a slide hammer to remove the bearings...the spacer in the middle is not designed to move around....otherwise it would fall out of placement when pulling the axle...
OR IT COULD COST ABOUT $1000 or MORE...!!!!!!!!...think about it
Beauty - 2008 Fully Farkled Red 685/II...
The Beast - 2002 VERY Nicely Farkled V-Strom DL1000 ...
Personal Tech Days...call 805-eight-nine-five-5114...DO NOT TEXT!!!
EagleMike Products (call 619-two-six-one-1281 or http://www.eaglemike.com)...
Old 08-06-2012, 06:17 PM   #6
andrewdonald1
Locale: puyallup
Postings: 78
I just did mine a couple weeks ago.
You can use a "drift" or punch. My spacer was a little seized, but working it with the punch as leverage you can get it to move enough to catch the edge of the bearing to knock it out.
A word of caution: make sure you install the bearings in the correct order that allow the spacer to go back in..don't ask me how I know this.. you have a 50/50 chance if you aren't paying attention.. I lost at those odds.. had to order another bearing..
andrewdonald1 is offline   Reply With Quote
Old 08-06-2012, 10:47 PM   #7
klrBill
klrBill's Avatar
Postings: 717
yes the hub is cast with little nubs inside that locate the spacer but let it move enough for bearing service. Also inspect the spacer when you have it out to see that it hasn't been mushroomed from bozo's that over tighten the axle. The klr spacer is pretty tough steel so not usually a problem but it's good practice. If the spacer is only a little bit short from abuse you'll have a bike that eats wheel bearings. Also if you find the cush hub bearing doesn't last long you may be running the chain too tight.
