| Maintenance, Mods, & Tech Wrenching and mods - KLR650 Maintenance discussion only! |
Locale: bettendorf, Iowa
Postings: 15
Greetings, I got a 2008 KLR . While on vacation in Idaho ( I live in Illinois) I had the oil changed. The mechanic could not get the drain plug loose and was cranking hard on the wrench (I was watching). He called over his 85 year old dad who walked over to him and got it free and said......"you were going the wrong way"..... the next day I noticed an oil leak, took it back and said "I think you screwed this up yesterday". He tried a washer as he said one was not on it...the next day oil leak (bought size of a quarter) on ground..so I took it in and he tried a cooper crush washer and some goup...next day oil leak.... so I went back and he said I would have to make an appointment so he could really look at it. Well I had to head back home so I reluctantly left Idaho without getting him to fix it....
So now I still have this damn leak....in about a three day span leak on ground is bout the size of the diameter of the top of a coffee cup. I been trying different washers, tried some pipe tape and still have a leak....the pipe thread tape worked to slow it down some... So today I swing by kawasauki dealer and mechanic gets down there and tells me I have a small crack right off drain plug hole. Since a helacoil will not work is there anything that might work on crack, like jbweld?......this really "bums" me out...If I have to get part of engine replaced would it be entire lower case(s) ?... ![]() |
#2 | |
Postings: 8,752
i would NOT have left...now you own the crack... it maybe only stripped threads if the plug was over tightened....stripped threads can be repaired with a HeliCoil....BUT it takes practice and a steady hand to properly drill out the threads... there are o-ring sealing washers....Chuck B gets his from GM...i get mine from McMaster.com/# good luck... wyman
CHECK YOUR OIL AT EVERY FUEL STOP!!! OR IT COULD COST ABOUT $1000 or MORE...!!!!!!!!...think about it Beauty - 2008 Fully Farkled Red 685/II... ![]() The Beast - 2002 VERY Nicely Farkled V-Strom DL1000 ... ![]() Personal Tech Days...call 805-eight-nine-five-5114...DO NOT TEXT!!! EagleMike Products (call 619-two-six-one-1281 or http://www.eaglemike.com)... ![]()
Postings: 15
Anyone? help!!!!!
Locale: Emmaus, PA
Postings: 578
See what wyman said ^^
This is why I do my own work...jeesh...was he really going the wrong way?
2002 KLR650 A16- the pleasant green 1992 Chrysler New Yorker - it was free |
Invisible Elitist 685 Boy
Locale: El Dorado Hills, CA
Postings: 4,004
In theory, JB weld can help.
In practice, it is best to take a "very focused picture" of the crack. You can also drain the oil, and take one with the plug removed. I would not ride the bike now, because once the engine heats up, there is no way to know how much more or less oil will leak out (likely more) when running it, so the amount of oil which had leaked out while it's been sitting is NOT indicative of the amount of oil which will leak when you ride. Disconnect the battery before you drain the oil, so you don't have a brain fart and start it with it drained... Awaiting those pics, so further solutions can be explored. So sorry this happened... K
Everybody Lies. I was lying when I said that. 08 - "Joker" "Error of Opinion may be tolerated where Reason is left free to combat it." - Thomas Jefferson |
Postings: 15
According to mechanic, there is a crack on the case right at 12 o'clock of the drain hole....I will attempt to take pictures after I drain oil......
Postings: 15
I have drained the oil out several times since this happened trying to fiqure out different washers, tape, etc..... I can say that when I drain the oil, I have not been losing all that much ......and I have been riding it....
Postings: 4,004
great...
Pic?
