Old 07-31-2013, 11:27 PM   #1
IRIDE
IRIDE's Avatar
Super Cool Since: Jan 2007
Locale: Odessa, Texas
Postings: 742
IRIDE is on a distinguished road
Default Is there a upgrade Rectifier 2005
I have a 2005 and I heard talk a while back of a upgrade for the rectifier,,,
Is it a plug and play item, Or do I have to rewire the whole thing,,,,
IRIDE is offline   Reply With Quote
Old 08-01-2013, 08:26 AM   #2
gronk
Locale: South Oz
Postings: 321
gronk is on a distinguished road
Default Re: Is there a upgrade Rectifier 2005
try doing a search on "mosfet". I've replaced my old R/R unit with a Mosfet unit, and it was fairly easy. Had to change the terminal plugs on the wires, and drill a hole to mount it. (mine's an '04)
gronk is offline   Reply With Quote
Old 08-01-2013, 11:15 AM   #3
oppy
Super Cool Since: Aug 2012
Locale: SC Wisconsin
Postings: 28
oppy is on a distinguished road
Just did this last weekend with a used R/R from a ZX10 I got on eBay for around $40 (it came in a Kawi box and looked brand new). Still waiting on the Triumph link lead to finish it up right, so I just plugged the female spade connectors into the replacement unit. Replacing the old burned-out rectifier was super easy.
oppy is offline   Reply With Quote
Old 08-01-2013, 03:31 PM   #4
kawioops
kawioops's Avatar
Super Cool Since: Mar 2006
Locale: To hell and gone from spoonbooty!
Postings: 5,282
kawioops will become famous soon enoughkawioops will become famous soon enough
SH010 or SH012 will do the trick. I bought mine used off E-bay for $25, came from a ninja, although that part # is also used on the Grizzly ATV's.
It's not plug and play as these use two connectors, but it's no biggie to wire them.
One Cool and Froody Dude who really knows where his towel is! You Sass?
kawioops is offline   Reply With Quote
Old 08-01-2013, 07:17 PM   #5
Ranger Ron
Ranger Ron's Avatar
Super Cool Since: Aug 2007
Locale: Sonoran Desert, AZ
Postings: 543
Ranger Ron is on a distinguished road
Those part numbers are for the shunt regulators. Probably a better option would be the mosfets. The mosfet numbers are FH010 and FH012.
I put a FH012 in my 2013. I think I paid $39 for it on ebay.
Ron
Ranger Ron is offline   Reply With Quote
Old 08-02-2013, 09:13 AM   #6
kawioops
kawioops's Avatar
Postings: 5,282
Ron
Yep. I got confused, thanx for straightening me out.
Old 08-02-2013, 09:20 AM   #7
Locale: Flagstaff, Az
Postings: 11,781
Chuck B is just really niceChuck B is just really niceChuck B is just really niceChuck B is just really nice
As everyone else stated...Mosfet. Wire it yourself, get plugs or wire harness from easternbeaver.com or triumph dealer.
Flagstaff, Az
Old 08-02-2013, 09:39 AM   #8
SmokinRZ
Super Cool Since: Sep 2010
Locale: Dallas, TX
Postings: 117
SmokinRZ is on a distinguished road
Is the regulator rectifier a common issue? Would it be a good idea to repalce it on a regular basis like on a VFR Honda? I venture many miles from home and don't need trouble.
SmokinRZ is offline   Reply With Quote
Old 08-02-2013, 09:44 AM   #9
Navy Chief
Navy Chief's Avatar
Locale: Waynesboro, PA
Postings: 702
Navy Chief is on a distinguished road
Go to the mosfet version and don't look back. They are much more stable and reliable.
Navy Chief is offline   Reply With Quote
Old 08-02-2013, 11:45 AM   #10
SilverCityzen
Site Supporter
Super Cool Since: Nov 2005
Locale: Southwest United States
Postings: 565
SilverCityzen is on a distinguished road
I got a plug-n-play replacement from racetechelectric.com. No wire changes, no drilling, just swap 'em.
I've only had it on there for a short time, no problems so far, but can't really give any opinion on longevity. But it's fine so far...
Best Regards,
SilverCityzen
SilverCityzen is offline   Reply With Quote
Old 08-02-2013, 12:50 PM   #11
IRIDE
IRIDE's Avatar
Postings: 742
I do not think its to common, Mine gets so Hot it can't last to long? I could be wrong
My 685 motard Rectifier is 14 years old and still working,,,I am headed to South America and I just want an ounce of precaution, Maybe over kill...
Old 08-02-2013, 10:30 PM   #12
wingerr
wingerr's Avatar
Super Cool Since: Sep 2005
Locale: NY, NY
Postings: 2,435
wingerr will become famous soon enough
The MOSFET regulator doesn't use an external sense line like the OEM SCR type, so it tends to be more forgiving of marginal batteries and connections (though the battery is still an integral and necessary part of the system).
The regulation voltage tends to be higher than with the stock regulator, and makes better use of the available power from the stator, because it's able to switch on and off at a very high frequency, whereas the OEM one can only switch at the stator frequency, and discards power unnecessarily in some conditions, like lower RPM.
We're all here because we're not all there ...o&o Be part of the solution. Not the precipitate.
8-D El Dooderino, if you're not into the whole brevity thing
wingerr is offline   Reply With Quote
Old 08-03-2013, 12:45 PM   #13
IRIDE
IRIDE's Avatar
Postings: 742
Looks like these rectifiers are the updated type, Plug and play and come with a life time warranty, Am I reading this right, That's had to beat...
Old 08-03-2013, 04:37 PM   #14
Postings: 11,781
I have his stator on my other KLR...working fine 1+yrs now. I use the Mosfet as my rectifier (BMW branded)
Flagstaff, Az
