Custom Search
Sidestand switch bypass - KLR650.NET - Your Kawasaki KLR650 Resource! - The Original KLR650 Forum!
Go Back   KLR650.NET - Your Kawasaki KLR650 Resource! - The Original KLR650 Forum! > KLR650.NET - Kawasaki KLR650 Forums > Maintenance, Mods, & Tech > Procedures & How To Articles
[REMOVE ADVERTISEMENT] 2008/2009 KLR650 Review
Old 01-22-2007, 05:16 PM   #1
flanga
flanga is on a distinguished road
Default Sidestand switch bypass
Total cost: about 60 cents. And it really was only 5 minutes, with no soldering needed.
I'll show the kickstand bypass, but you can do the same thing for the clutch.
No need to disconnect anything. Just remove the vertical black switch cover on the left side of the bike. Snip the wires (brown/green+white) leading from the kickstand to the red plug under the seat. Securely crimp on insulated quick-disconnects (available at any hardware or autoparts store). Alternate male/female ends so they can connect together. Like so:
Elapsed time: maybe 2 minutes so far.
Next, take a hunk of scrap wire (a few inches--- length is mostly irrelevant) and crimp quick-disconnects to each end, male on one end, female on the other, or whatever gender you need to mate with the quick-disconnects you put on the upper wires. Thus:
Elapsed time: maybe 3.5 minutes
To bypass the kickstand switch, just plug the scrap wire into the upper quick-disconnects, as a jumper between them:
I tucked the lower wires coming up from the kickstand out of the way, and filled the quick-disconnects with dielectric grease.
Put the cover back on (1 screw) and you're done--- in five minutes or less.
If/when you want to reactivate the switch, just remove the jumper and reconnect the upper and lower wires. You can reactivate/deactivate the switch by installing and removing the jumper as often as you need to in about 2 minutes or less. No muss, no fess, no soldering--- and for pennies.
flanga is offline   Reply With Quote
Old 01-22-2007, 06:25 PM   #2
MapBoy
Gunga galunga
MapBoy's Avatar
MapBoy is on a distinguished road
Default
Awesome post Fred!
I am electrically incompetant, but even I will be able to follow those instructions.
Nice pics too!
Well Done!
MapBoy is offline   Reply With Quote
Old 01-22-2007, 06:35 PM   #3
imported_ktrout37
imported_ktrout37 is on a distinguished road
Default
Originally Posted by MapBoy View Post
Awesome post Fred!
Nice pics too!
Well Done!
2nd!
imported_ktrout37 is offline   Reply With Quote
Old 01-22-2007, 07:07 PM   #4
wingerr
wingerr's Avatar
wingerr is on a distinguished road
Default
Just as a variation on the theme, you could also crimp on the disconnects with a male and female on the switch side, and also on the harness side, so you don't have to carry around the extra jumper.
To bypass, all you would then need to do is just connect the male to female on the harness side.
We're all here because we're not all there ...o&o
.8-D El Dooderino, if you're not into the whole brevity thing
wingerr is online now   Reply With Quote
Old 01-22-2007, 07:28 PM   #5
oregon07klr
oregon07klr's Avatar
oregon07klr is on a distinguished road
Default
Seems simple but have been wondering for a while now, what is the purpose of disconnecting the clutch/sidestand safety switch?
oregon07klr is offline   Reply With Quote
Old 01-22-2007, 07:45 PM   #6
flanga
Default
They have a tendency to fail, and it can be a PITA to troubleshoot when you're on a ride.
Old 01-22-2007, 07:47 PM   #7
BTL
RUSHaholic
BTL is on a distinguished road
Default
Because these switches fail at inoppertune moments and can leave you stranded and scratching your head as to why the bike won't run...
BTL is offline   Reply With Quote
Old 01-22-2007, 07:49 PM   #8
flanga
Default
True! I didn't think of that in time, and had clipped the wires too close to the red plug--- not enough slack to put the quick-disconnects together.
Old 01-22-2007, 10:38 PM   #9
broncobowsher
broncobowsher is on a distinguished road
Default
If you can find a source of these http://www.delcity.net/delcity/servl...=185639&page=1 they are soldered and heat shrinked and a bit more weather resistand then the hardware store version. The solder melts while the shrink is shrinking with a lighter. Neat stuff. Looks like you may have to use bullet connectors.
broncobowsher is offline   Reply With Quote
Old 01-23-2007, 02:11 AM   #10
mule
mule's Avatar
mule is on a distinguished road
Default
bypass? just eliminate it forever, well that's what id did at least to all of the idiot switches on my bike. and still feeling pretty safe.
mule is offline   Reply With Quote
Old 01-23-2007, 04:01 AM   #11
MarineMP
MarineMP is on a distinguished road
Default
Thanks for the tips and the great how to.
MarineMP is offline   Reply With Quote
Old 01-23-2007, 05:55 AM   #12
Woolly
Woolly's Avatar
Woolly is on a distinguished road
Default
Flanga
Good to see great minds think alike - I did the same mod 7 years ago, and still going strong.
Woolly
Woolly is offline   Reply With Quote
Old 01-23-2007, 12:27 PM   #13
humvee
humvee's Avatar
humvee is on a distinguished road
Default
So much easier when you have the pics - thanks for taking the time!. Can anyone demo the clutch bypass?
humvee is offline   Reply With Quote
Old 01-23-2007, 03:02 PM   #14
mylibu
mylibu is on a distinguished road
Default
[quote=humvee;57618]So much easier when you have the pics - thanks for taking the time!. Can anyone demo the clutch bypass?[/QUO
I second that request...great thread by the way!
mylibu is offline   Reply With Quote
Old 01-23-2007, 04:09 PM   #15
Mr. Toad
Mr. Toad is on a distinguished road
Default
If you take a piece of silly putty, or pipe sealing putty, and make an impression of the connector on the bike side you can carry that to the local electronics shop, or bike boneyard and get a plug to fit. I found an already made up jumper on an older Honda Spree scooter. I just removed everything having to do with the switch and all and plugged this in. It made enough room under the solenoid cover to mount my power outlet to charge the cell when camping. I still have the leftovers should I care to go back to stock. Don't think that will happen but hey. Great to have the picks for those going the cut and solder route though, and easy to undo. Keep em coming.
Mr. Toad is offline   Reply With Quote
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
