| Maintenance, Mods, & Tech Wrenching and mods - KLR650 Maintenance discussion only! |
Super Cool Since: Feb 2006
Locale: Northwest Mississippi
Postings: 176
Hi!
How do you get the rear wheel off the 1100 V-Star? I am putting on new tires for a lady in our Motorcycle Club and have run into a serious problem! After pulling the axle and the brake caliper the wheel could not slide over far enough to remove due to the bracket that holds the brake caliper being in the way. The only way I can see to get the bracket out is to first remove the brake disc. Is that the correct procedure? So, I begin removing the allen head bolts holding the disc on and one of the socket heads stripped out! I have not yet been successful in removing the bolt. Any ideas? Is there a better way to remove the wheel? I sure wished she had a shop manual! Thanks! Donnie |
Super Cool Since: Aug 2007
Locale: B.C, canada
Postings: 385
Its bean a few weeks since I did one of these but I think there is a bolt that holds the mount for the caliper to the swing arm, remove this bolt and the whole mount lifts out.. NOT necessary to remove the rotor.
Gene |
Postings: 717
4 bolts and remove the shaft drive unit, grease the shaft splines with a moly grease while it's out. change the oil yet?
"Better is often the enemy of Good Enough" |
Postings: 176
Thanks! I completed the tire change.
| front wheel bearing removal | Bicycle Phil | KLR650 Main Discussion | 3 | 07-13-2004 12:12 AM |
| Chinese Rear Wheel Bearings? | ryano | Maintenance, Mods, & Tech | 2 | 05-09-2004 02:49 PM |
| 18" rear wheel, anyone done it? | 02KLR650 | Maintenance, Mods, & Tech | 6 | 04-14-2004 07:27 AM |
| Rear Wheel | Julie | Maintenance, Mods, & Tech | 4 | 02-03-2004 07:31 PM |
| Trouble mounting rear wheel | BMWCMW | Maintenance, Mods, & Tech | 5 | 08-28-2003 04:48 PM |
