Reading about the problems people have starting in cold weather got me thinking about ways to improve starting in general. The obvious improvement would be to reduce the battery load as much as possible when starting.
As soon as you turn the key the battery sees a 6 amp load, all but about .25 amps going to the headlight and tail light. Keeping both off will make more power available to the starter and ignition, a big help in the cold when batteries provide less power. Your battery should last longer, and will recharge sooner. This mod is both cheap, easy, and reliable. I installed a horn relay from the junk yard but you can get them at any auto parts store. An old relay is fine as the "normally closed" contacts are used ... if the relay croaks the headlight stays on during starting, no biggee. Here's the relay, a standard 12v automotive relay. ![]() Pins #30 and #87a are hooked up to the 10amp light circuit, the brown wire going to the fuse block under the seat. On mine I just chopped off the bullet connectors and crimped on some female insulated spade connectors. Pins #85 and #86 drive the relay and I wired them directly to the starter relay. ![]() I had connectors on hand but quality insulated butt connectors spliced on directly is easier and I would think more reliable. The relay fits under the seat on top of the airbox. ![]() Total parts should be $10-$15 max ... labor about an hour. Bat
"People don't ask for facts in making up their minds. They would rather have one good, soul-satisfying emotion than a dozen facts." Robert Keith Leavitt |
------------------- Hell of a plan, dont kno why kawie didnt do this from day 1, lot of other skooters have this built in from the factory..
GSXR 1000/2004, touring bike KLR 650/08 red, of course Skooter wrench a fine is a tax for doing wrong, a tax is a fine for doing well |
I was thinking of doing the same thing because I was having a cold start problem too. If I just put an on/off switch on the headlight circut will it cut off the tail light too? Could you write your mod in a schematic? Cheers.
'99 ZRX1100 '03 KDX220R '05 KLR650 '73 CL450K5 '03 F250 (Ford) |
#4 | |
Switching out at the fuse turns off the tail and instrument lights in addition to the headlight. Switching off just the headlight is ok as it has the biggest draw but I don't like the idea of possibly riding without a light. Ultimately I plan on doing a mod where the headlight had dedicated power that is relay controlled and another relay that keeps all the non-essential loads off when the engine is not running. I also want to install an led on the instrument cluster that will go on whenever the headlight is off. Bat
Level 3 Moderator
if you're using an aftermarket or homebrew wiring harness to dwar power for the headlight directly from the battery, this should be an easy change.
have you pulled your doohickey lately? KLR 650: Dirt Ninja • KLR 250: the ugly duckling, undergoing rehab ![]() √ote Libertarian! perpetuate the KLR stereotype, visit the Deals Forum
BatRastard,
r u sayin u just cut the brown wire in half then added plugs on each cut end...then hooked to 30 & 87A. then same for starter relay wire to 85 & 86?
see u on the road scag... There will only be two things left moving after WW3. Cockroaches & KLRs. |
Just a quick warning about cheap auto relays. I picked up a couple of them from my local Advance auto parts to use for an extra driving light but they kept screwing up. I finally took one apart and found it full of rust and corrosion from too many stream and puddle crossings (mine were mounted below the headlight). To fix this I just sealed the cap to the base with ordinary old silicone. I think they were really made for use inside a car rather than strapped onto a KLR.
KLR Fanatic
Nice mod, Bat.
![]() I'm going to do it. |
#9 | |
your own wire at #85 and #86 and run it down to the starter relay to tap in there. The relay doesn't draw much power so the quality of the insulation on the wire you use is more important than the gauge. Bat
#10 | |
Because the contacts used are closed when the relay is off, a relay failure is not a problem. On rare occasion a relay contact can stick but usually that's from too much current. Never say never tho' ... I'll be modding my mod. Thanks, Bat
BatRastard,
piece of cake man, just finished up. had a spare relay out in garage...everything works perfectly. soon as i hit starter...head light and tail light goes out and comes back on soon as i release starter button. turns out, it is same procedure as hookin up auto comp releases on ss 124 engine i installed in harey i used to have. great mod...thanks for heads up...i dig it.
#12 | |
Bat
#13 | |
Edit: Forgot to mention something: Great post!!
Broken legs suck, but hardware removal is good. Metal free since 08/30/07 Last edited by SDMF_Reaps : 02-24-2008 at 08:19 PM. |
#14 | |
That's the kind of setup on an 85 Ninja, where the headlight stays off until after you press and release the starter; then it stays on. It stays off from the time you turn the ignition on until you start it up, which is a bit better, since you don't get that initial drain right after switching on. The KLR can be retrofitted to do that with a few relays; I drew out a circuit to do it but never bothered to try it yet. I was thinking something simpler like just cutting off the headlight circuit when the neutral switch is on, so when I'm starting it up and idling the headlights will remain off even after starting. I'd add an override switch to keep the lights on in situations if I need to be sitting in traffic in neutral. BTW, relays can definitely still fail even in the off position when using the normally closed contacts; the contacts can corrode just as easily and fail to pass the current. If anything, they may even be more prone to failure than the normally open contacts because they have lower contact force. Usually the NC contacts are rated for slightly lower current capability than the NO contacts, because they only have spring tension holding them closed, as opposed to the coil pull when energized. Sealing the relays would definitely be a good idea in a KLR environment-
We're all here because we're not all there ...o&o.8-D El Dooderino, if you're not into the whole brevity thing Last edited by wingerr : 02-25-2008 at 08:59 AM. Reason: update description |
#15 | |
a situation where the coil in the relay fails. The standard horn relay is rated at 20 amps on the normally closed and 30 amps for normally open. Sealing the base of the relay is a great idea, and if you get a relay from a junk yard it would be a good idea to pop the cover off and inspect the contacts. It sure is great to have a forum like this where mods get presented and improvements to the idea added on. Later, Bat
