Old 11-30-2008, 06:44 AM   #1
MotoMo
Super Cool Since: Nov 2006
Postings: 612
MotoMo is on a distinguished road
Default Lock rear wheel, change front sprocket
People often find it difficult to stop the rear wheel from spinning when they are trying to break loose the factory-over-torqued nut which holds down the front sprocket.
To stop the rear wheel from spinning, people have suggested:
1. Deflate the rear tire, then stuff rags between the tire and the front of the swing arm, and then re-inflate the tire.
2. Get another person to sit on the bike and press the rear brake pedal down to lock the rear wheel.
3. Insert something like a broomstick through the spokes, above the swingarm.
I changed my front sprocket yesterday. Not having another person handy at the time, I tried #1, without success. I did not try #3, as I was afraid that I could bend a spoke or two.
This is what I did to keep the rear wheel from spinning:
I inserted some strong cord down in front of the swingarm (just behind the shock absorber), led it back to the rear wheel, passed it through the lower/forward part of the rear wheel (behind a spoke nipple), and then led it back and down through the front of the swing arm again. I did that several times with one length of cord, passing the cord behind a different spoke nipple each time, in order to divide the load between two or three nipples. Then, I tied the ends of the cord together. The bike did not budge when I had to apply more than 160 foot pounds of torque to the sprocket nut to break it free. Nor did the spokes bend at all.
I offer the procedure as a suggestion which works well.
It was an easy solution to a tough problem.
MotoMo is offline   Reply With Quote
Old 11-30-2008, 06:48 AM   #2
mcfear
Locale: Queensland - Australia
Postings: 2,135
mcfear is on a distinguished road
Default Re: Lock rear wheel, change front sprocket
i just take the chain off, and then put it in first gear.
Originally Posted by MSGT-R
McFear, you're turning into one hell of a mechanic!
the master of the KLR250 said that ^^^
2009 CB400 -Red/White/Blue TriColoure
2006 DR650 blue one
2005 KLR650 - Red/Black (TOTALED )
1994 KLR250 - barbie color scheme. (SOLD)
1974 Honda CB250 twin cylinder - blue
1970 something, honda minitrail 50cc monkey bike. - red
mcfear is offline   Reply With Quote
Old 11-30-2008, 08:09 AM   #3
MotoMo
Postings: 612
That would not have worked with my bike. The engine would just have turned over. It required more than 160 foot pounds of torque to break the nut free.
Also, using the method I suggest, the transmission and clutch do not have to bear the strain of the torque that has to be applied to break the nut free.
To each his own, I guess.
Old 11-30-2008, 09:21 AM   #4
KLR-dude
KLR-dude's Avatar
Super Cool Since: Mar 2007
Locale: puslinch,ontario,canada
Postings: 397
KLR-dude is on a distinguished road
that is an exelent way to bust the gears. hehe!
the dude
http://latitude54.blogspot.com/
KLR 650
BMW K1200GT
BMW K 75
yamaha virago 1000
honda xr100r
yamaha YH-1 305 c.c. 2 stoke in basket
KLR-dude is offline   Reply With Quote
Old 11-30-2008, 09:43 AM   #5
ki4glx
ki4glx's Avatar
Super Cool Since: Sep 2007
Locale: Anniston Alabama
Postings: 1,209
ki4glx is on a distinguished road
Just use an impact. Just my though.
Never argue with an idiot because those that are watching will not be able to tell the difference.
You start out motorcycling with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before you empty the bag of luck.
'85 KLR600
'04 KLR650
ki4glx is offline   Reply With Quote
Old 11-30-2008, 12:50 PM   #6
fixer
Rank: Expert
fixer's Avatar
Super Cool Since: Sep 2003
Locale: Lost Wage$, NV
Postings: 13,606
fixer will become famous soon enough
ride an older bike.. then it's just two small bolts instead of one big nut.
have you pulled your doohickey lately?
KLR 650: Dirt Ninja KLR 250: the ugly duckling, undergoing rehab
√ote Libertarian!
perpetuate the KLR stereotype, visit the Deals Forum
fixer is offline   Reply With Quote
Old 11-30-2008, 12:52 PM   #7
willys
Rank: Expert
willys's Avatar
Locale: padded room
Postings: 12,162
willys is on a distinguished road
It's funny how an impact can overcome the littlest of issues...lol
willys is offline   Reply With Quote
Old 11-30-2008, 05:39 PM   #8
mcfear
Postings: 2,135
or the largest impacts lol, hey scott. instead of DUCK!!!!! its DEER!!!!!!!
on mine i got a fairly knobby rear on (its a 250 so not as much compression) and have only had to take chain off and do it that way once, but i have the 2 nuts on it instead of the one. and it didnt take much, definately not 160.
are all the single nutters out there on that tight?
2006 DR650 blue one
Old 11-30-2008, 05:47 PM   #9
Spiderman
Spiderman's Avatar
Super Cool Since: Jan 2005
Locale: Decatur, IL
Postings: 235
Spiderman is on a distinguished road
I think I remember hearing of another technique. Stuff a rag between the front sprocket and chain. Turn nut till it jams then go ahead and give it hell. I'm interested to see what others think of this idea.
Spiderman is offline   Reply With Quote
Old 11-30-2008, 06:12 PM   #10
mcfear
Postings: 2,135
that sounds like it would work, but might take a bit of turning. what about an old tire tube. would take less to make it lock i woulda thought
2006 DR650 blue one
Old 11-30-2008, 07:52 PM   #11
KLR-dude
KLR-dude's Avatar
Postings: 397
my nut was verry tight (single)
i would have damaged the gears for shure,having no inpact wrench
i had to beat the living sh1t out of it
could not believe the pounding it took to undo that sucker
the dude
KLR 650
BMW K1200GT
BMW K 75
yamaha virago 1000
honda xr100r
Old 11-30-2008, 08:22 PM   #12
mcfear
Postings: 2,135
fair enough.
2006 DR650 blue one
Old 11-30-2008, 09:06 PM   #13
MotoMo
Postings: 612
With the very tight ones (I measured the torque on my '04, using a torque wrench, as exceeding 160 foot pounds), an impact might not be too good for the transmission, either -- just my opinion, unsupported by personal experience, because, being the cautious guy I am, I didn't try it -- and because I don't have an impact.
But it just takes a minute to tie the rear wheel to keep it from moving, using the method I have suggested.
That works very well, and none of the torque is transmitted to the transmission.
Also, when you are re-torquing the nut after having replaced the sprocket and lock washer, do not to allow the engine to rotate backwards. Tie the rear wheel again, moving the loop of cord to the front/top of the wheel. Distribute the load between two or three spoke nipples.
Old 11-30-2008, 09:24 PM   #14
MotoMo
Postings: 612
That would generate tremendous tension on the chain, as the chain would try to ride over the lump of rag stuffed between it and the sprocket. Could that do damage to the countershaft and wheel bearings? I dunno.
I think it could also bend the chain, if the chain, being disengaged from the sprocket teeth, slipped over the lump of rag to one side or the other of the sprocket. I think it could also result in a severely jammed up mess.
A section of inner tube would very likely be cut to shreds by the chain and sprocket.
I guess you can tell I am impressed by how much torque it took to break the countershaft nut free. The nut must have been installed originally by a pair of crazed gorillas on amphetamines and steroids.
Old 11-30-2008, 09:36 PM   #15
DaWhip
Site Supporter
DaWhip's Avatar
Locale: Austin, TX
Postings: 694
DaWhip is on a distinguished road
Where is scott anyway? It has been more than 24 hours since I have seen a post from him! I think we are supposed to worry after 4 hours with him. What did he kill now?
Blow up your car...Ride a bike
DaWhip is offline   Reply With Quote
Old 11-30-2008, 10:05 PM   #16
fixer
Rank: Expert
fixer's Avatar
Postings: 13,606
don't doubt that any shop would use an impact gun.
i'm not saying it's a GOOD thing for frequent abuse... but occasional use probably won't be a problem.
nothing wrong with the trick of tying up the rear wheel that i can see however, and it would eliminate any stress being transferred to the transmission.
√ote Libertarian!
Old 11-30-2008, 10:51 PM   #17
nooner818
A Regular PITA!
nooner818's Avatar
Super Cool Since: Mar 2006
Locale: Forest Ranch, CA
Postings: 1,589
nooner818 is on a distinguished road
Me, I just situated myself on the right side of the bike and depressed the rear brake pedal with my foot.
Then I leaned over with a long breaker bar and...
Presto!
Nooner
Lefty - Loosey
Righty - Tightey
'Kinda sums things up, doesn't it?
nooner818 is offline   Reply With Quote
Old 12-01-2008, 12:05 AM   #18
2wheelsrbest
D14TYD33D5 D0N3D14TC#3AP
2wheelsrbest's Avatar
Locale: NW Seattle, WA
Postings: 606
2wheelsrbest is on a distinguished road
Bingo nooner!
Let's see...I'm looking for a simple device to keep the rear wheel from moving. Hmmm... What could possibly work?
Super glue? Not a big enough tube on hand...
Rig up a tow chain, lawn chair and a magnifying glass? No lawn chair...
Mr. T? No. I lost his phone number...
Rear brake?
Even if you've already cut the old chain, you can re-run it and ziptie it together so that top run of chain is under tension.
2wheelsrbest is offline   Reply With Quote
Old 12-01-2008, 02:18 AM   #19
MotoMo
Postings: 612
Originally Posted by 2wheelsrbest View Post
Bingo nooner!
Rear brake?
I don't think you would have broken my bike's nut free by standing on the rear brake. I tried it. When it takes more than 160 foot pounds to break the nut free, you begin to wonder when you are going to damage that not very strong rear brake lever. It's better, in my opinion, to just tie the rear wheel down, and avoid the strain on things like brakes and transmissions.
Anyhow, I'm not looking for an argument. Just trying to make a helpful suggestion. To each his own.
Old 12-01-2008, 03:06 AM   #20
mcfear
Postings: 2,135
the rag stuffed inbetween would slip with the chain. would need to remove the chain for the teeth to grab the rags. but it could take a hell of a lotta rag maybe.
2006 DR650 blue one
