Old 04-14-2009, 04:43 PM   #1
KRMN8R
KRMN8R's Avatar
Locale: Brisbane Queensland Australia
Postings: 76
Default Synthetic Oil?
Simple question: I've done 7000kms (4349 miles) using mineral oil, is it time to switch over to synth?
Yamaha DT250A
25 year break.
08 KLR650
KRMN8R is offline   Reply With Quote
Old 04-14-2009, 04:52 PM   #2
Arizona14
Arizona14's Avatar
Locale: Fountain Hills, Arizona
Postings: 719
Default Re: Synthetic Oil?
What kind of oil you put in your bike is a religious matter. Everyone has something that they believe in and won't change their mind, ever, no matter what.
With that basic understanding in mind, IMO, I would wait until you have about 8,000 to 10,000 miles on the engine just to let all the bearings settle in and be happy.
Ride safe.
Arizona14 is offline   Reply With Quote
Old 04-14-2009, 06:34 PM   #3
OldBaldy
Sneaky Slow
OldBaldy's Avatar
Locale: South Lyon, MI
Postings: 566
No, due to the cyclical resonance T-factor of the single's crank and gear phasing, I'd strongly suggest you change over on an even number of miles. You should run the bike 0.5 miles down the road and back, to switch the oil at exactly 4350 miles...and try not to do it other than in units of 50 miles, so if you don't do it at 4350, then wait until 4400.
Never, ever, switch over after 5000 miles.
Otherwise, you'd be taking your chances and no-one could predict the value or benefit to you of the changeover....
Old Baldy / WWBO #451
Ducati 996
Kawasaki KLR 650 '02
Kawasaki KLR650 '06
OldBaldy is offline   Reply With Quote
Old 04-14-2009, 06:52 PM   #4
swjohnsey
Super Cool Since: Jan 2004
Postings: 6,172
Yes.
swjohnsey is offline   Reply With Quote
Old 04-14-2009, 08:19 PM   #5
Blackheart
Locale: Morgan, Utah
Postings: 2,296
Only if you also change your right turn signal fluid at the same time.
Look, there is NOTHING magic about "synthetic" oil. Most of the oil labeled thusly isn't really synthetic, it's simply severely hydrocracked. Seriously, people, get over the idea synthetics are some sort of mystery.
Use if from mile 1 if you want.....
Blackheart is offline   Reply With Quote
Old 04-14-2009, 08:25 PM   #6
MrHeadfirst
Wherever I may roam
Locale: Brazil, Indiana
Postings: 39
being new to the KLR650.NET, i dont understand what kinds of oils i can even use in this bike...the clutch is lubricated by the engine oil correct? in my older street bikes, you had to use a special oil that would also be compatible with the clutch, is that also the case with this bike? that being said, what should you use???
MrHeadfirst is offline   Reply With Quote
Old 04-14-2009, 08:35 PM   #7
hunter
hunter's Avatar
Super Cool Since: Mar 2004
Locale: Houston, Texas
Postings: 506
Unhappy Re: Synthetic Oil?
Stupid question what is synthetic oil any way? I use it but don't know what it is.
hunter is offline   Reply With Quote
Old 04-14-2009, 09:02 PM   #8
fergie
fergie's Avatar
Super Cool Since: Mar 2006
Postings: 470
yes do it. I use kawisaki full sythetic.
I'd give my right arm to be ambidextrous
fergie is offline   Reply With Quote
Old 04-14-2009, 09:08 PM   #9
Blackheart
Postings: 2,296
Suffice it to say, "Synthetic" is a marketing-derived term, not a scientifically-derived term. If it has the correct friction modifiers in it, it's great to use for wet-clutch bikes, JUST LIKE oil that is NOT labeled as Synthetic. Also, many oils that are NOT rated specifically for wet-clutch systems do perfectly fine.
If you want to know more, google a site that begins with Bob, and it's about oil. Pay attention, read the papers, not just every Jane, Dick, and Harry, and you'll learn more than can be found in most every thread on the subject. If you don't want to make the effort, just use Kawasaki oil or Rotella, and fuggetabout it.
Old 04-14-2009, 09:10 PM   #10
klr4evr
klr4evr's Avatar
Locale: Alberta, Canada
Postings: 610
That will set you back a few $$$$
klr4evr is offline   Reply With Quote
Old 04-14-2009, 11:01 PM   #11
KatLoveRhoid
Super Cool Since: Feb 2008
Locale: Austin,TX
Postings: 36
I just change to Mobil 1 synthetic on my 2008 KLR with 9K miles.
What a difference! It is quieter, smoother and better shifting!
My bike burns a small bit of oil, like a few ounces after a few hundred miles of highway use, so I will top it with the same.
I just installed the PCV valve, so I will monitor my oil use, and see if it goes down.
PS: I love riding my KLR!
www.RideDualSport.com/forum
KatLoveRhoid is offline   Reply With Quote
Old 04-14-2009, 11:04 PM   #12
Swiftbow
Hunt'n fer sixth
Swiftbow's Avatar
Super Cool Since: Oct 2003
Locale: Santa Fe, NM: North of Spoonbooty
Postings: 4,111
Blackheart has it, while oils extrolling the term "SYNTHETIC" abound, most are not truly synthetics.
Doug
"Accelerating into ... neutral"
Swiftbow is offline   Reply With Quote
Old 04-15-2009, 04:20 PM   #13
MrHeadfirst
Wherever I may roam
Postings: 39
so mobil 1 synthetic engine oil is ok to use?
that wont damage the clutch? do we know this for sure?
the only reason i ask, is that i have known many people to have caused damaged to their clutches by using mobil one, or other synthetics. granted, this has been on older model street bikes.
i just want to be sure before i add it to mine.
i have been a lifelong user of mobil one, and i would love to use it in my bike,
Old 04-15-2009, 04:45 PM   #14
swjohnsey
Postings: 6,172
You can't never tell. I've been usin' Mobil 1 15w50 in my ole KLR650 for 75,000 miles and the clutch may go out tomorrow.
Old 04-15-2009, 05:00 PM   #15
Xtreme
Locale: Arkansas
Postings: 2,524
Mobil 1 is not synthetic but it's very good oil.
Schnitz Racing 685 & 705 Big Bore Kits
http://www.schnitzracing.com
Xtreme is offline   Reply With Quote
Old 04-15-2009, 05:03 PM   #16
MrHeadfirst
Wherever I may roam
Postings: 39
how is mobil 1 not synthetic oil?
Old 04-15-2009, 05:10 PM   #17
Blackheart
Postings: 2,296
look up the lawsuit Mobil had against Castrol. The very thing Mobil complained about, that Castrol was using a severely hydrocracked petroleum base instead of a true "man-made" base molecule, Castrol couldn't use the term "synthetic". Mobil lost. Now, Mobil uses a "Group III" base, just like Castrol did.
As I said, the term "synthetic" is marketing based, not scientifically based.
Old 04-15-2009, 08:09 PM   #18
MrHeadfirst
Wherever I may roam
Postings: 39
i didnt know that,
i will look that up, thanks for the interesting info.
Old 04-15-2009, 08:46 PM   #19
slappy00
slappy00's Avatar
Super Cool Since: Mar 2009
Locale: Chicago
Postings: 121
"From the information given to me last, EVERY synthetic on the market today has converted over to this Group III oil, with the exception of most of the Amsoil line, Mobil 1, and a few other specialty oils"
http://www.technilube.com/faqs_info/synth_diff.php
so Mobile 1 is fully synthetic?
slappy00 is offline   Reply With Quote
Old 04-15-2009, 09:50 PM   #20
Swiftbow
Hunt'n fer sixth
Swiftbow's Avatar
Postings: 4,111
Need to look at the date Slappy. The report is from six years ago. Mobil 1 used to be synthetic.
Doubtful anyone has any concrete statements or documents from the last few years showing what Mobil's basestock truly is. Mobil used to openly declare their basestock was PAO, however, now they don't.
Description of their product proudly declares full 100% synthetic but nothing about if it's a PAO or Ester based true synthetics.
There has even been a few internet post from people where they pointeably asked Mobil if their oil was synthetic or highly refined crude. The form responses from Mobil declare their oil is 100% synthetic but no comment about the derivation.
The avoidance response and the removal of the description about PAO has led to the suspicion that Mobil is no longer a true synthetic.
Doug
