| KLR650 Main Discussion First generation KLR650 Related Topics, 1987-2007 |
Locale: Southern California
'Scuse me if this is an FAQ, I thought it might be but I could not find any threads, feel free to point me in the right direction if this has already been discussed...
I am considering the new KLR as a first bike. My jeans are 30" inseam and when I straddle the KLR I can get the balls of my shoes on the ground but no way can I flat foot it. I straddled a BMW 650 XCountry, which fit very nice, and it looks like it would be a great bike, but at nearly 2X the price...yikes. So is this within the range of acceptable fit? Is there anything you can do to lower it a bit - thinner gel saddle (I have seen this on other models), lower the suspension (yeah, maybe I am not tall enough for all that travel anyway) or what? |
Locale: Gone fishin'
Postings: 10,744
You are plenty tall enough for the KLR. Why would you need to flat-foot both feet? If you can get the balls of your feet down, you can plant one foot at a stop. That is all you need. I do fine with my 28" inseam.
Many riders feel the need to lower their bikes, but soon return them to stock height as they gain experience. Of course, many prefer a lowered bike, but I think they would typically be a lot shorter than you. |
Ultra-noob
Locale: Lehigh Valley, PA
Postings: 226
AFA not being able to flat-foot it: plenty can't, but it's probably not the best for a new rider.
The bike can be lowered by raising the fork tubes in the triple tree and changing out the suspension linkage (search this site for "lowering links"). If you raise the front and back by different amounts, that can change the handling characteristics of the bike. It's also possible the bike you sat on had the suspension pre-load set too high and it didn't "sag" with you on it. I don't know for sure, but it's supposed to sag 2 or 3 inches when you're mounted (meaning the suspension squishes under your weight making the seat 2 or 3 inches shorter.) Lower seats help, too, I guess - I have the opposite problem so I don't know much about that. HTH
Steve 06 KLR 650: Gone to a good home 6/4/09 |
Locale: Dallas Ga.
Postings: 298
Only 2 sets of balls may be touching at any given time on a klr.........................one set on the seat, and one set on the ground, heh heh heh.
"It aint got no gas init !"Karl Childers 1998 KLR650 2006 KLR650 1976 CB750K |
Locale: AZ
Postings: 48
I am 5'6'' and fit on the KLR fine. It is not a street bike so you will not be two footing it while stopped. I can put one foot down flat to the heel at a stop once I am seated on the bike. Offroad you will only need to bounce a toe off the ground every once in a while for balance when things get real rough and it has never been an issue for me. It is just different getting used to sitting up that high.
Super Cool Since: Oct 2008
Locale: Western, NC
Postings: 491
While I'm not a beginner rider, I am relatively new to "tall" bikes. I rode mostly cruiser style bikes where I was flat footing with bent knees. I was a little nervous when I first climbed onto my KLR. I too could only touch with the balls of my feet. After a short while, I got used to reaching for the ground and supporting the bike on one foot at stop lights. Now I really like the height and will likely not go back to a lower bike. My advice is to try the bike in its stock configuration first. Before I bought the bike, I thought I was going to need to lower the bike but now I'm glad I left it stock. Good Luck.
Super Cool Since: Feb 2007
Locale: NE Ohio
Postings: 488
It's a tall mans bike!!! Get over it! If all this complaining about it being too tall makes them lower it in the future and messes up the ONLY bike I found to fit me I'm gonna be miffed!!!!!!!!!!
Just teasing everyone sorry to get you riled! Raising links and a taller saddle for me.... That is when the short one (wife) says I'm allowed to.Last edited by bulacouple : 04-20-2009 at 07:01 AM. |
#8 | |
Super Cool Since: Mar 2009
Locale: Kingman AZ
Postings: 75
You will get many differing opinions and they are all valid! Sort through them and find what fits with your comfort level. I too have a 30 inseam. I lowered my KLR and I'm glad I did. First ride I took, I wound up traveling on a 4 mile downward slope that had lots of loose and sometimes deep sand. I had to foot my way through at times and sure was glad that I could plant a foot firmly as needed.
Ed Anderson Kingman AZ 07 Vulcan 1500 Classic 08 HD FLTR 09 KLR 650 |
Locale: Ottawa, Ontario
Postings: 640
Well, I don't know what DirtDad thinks of all this but, at 5'10" myself and not having ridden my KLR yet, I feel a little more comfortable about the whole thing after hearing from others
I'd sat on one that was lowered 3" and it made a big difference in terms of making it less imposing. But I'm going to try mine stock and see how I like it... |
I am going to try mine stock when I finally get it, I will be smart enough to talk to the dealer about making adjustments if I want them later.
I have a lot of mountain bike experience. This sounds like it is similar to bottom bracket height on a full suspension MTB (with obvious differences). A higher bottom bracket may take a while to get used to, but once you learn to handle them they provide better clearance. |
Locale: Michigan
Postings: 227
I rode mine stock for a while but just wasn't comfortable with the lack of control at stoplights due to the ball of feet height of the bike . I am 5'-10" but don't have that long of legs.
I have installed the 2" lowering links and feel I have much more control over the bike. |
#12 | |
Transformer catscradle
Locale: Alaska 843521 rods NW of Spoonbooty
Postings: 3,159
For every guy who still has the lowering links, there are another 10 who used them for a couple months, then took them off when they got comfortable with the bike. That said, the Corbin seat is nice- both comfort and height.
We had part of a Slinky. But I straightened it. |
#13 | |
Thank You
Locale: Mass Hole a chew sets
Postings: 1,423
#14 |
Locale: Brisbane, Australia
Postings: 56
I'm 6 foot and at first I thought the KLR was a bit of a handfull with the standard links - I could just flat-foot. Now I'm much happier with the Eaglemike raising links, which improve both ride and handling, and allow you to carry a well-upholstered pillion and luggage without scraping the SW Motech centrestand on a tight corner. The KLR balances beautifully - as long as your big toes can reach the ground you're fine IMHO. I did have to add a bit of hardwood on the bottom of the sidestand, however, to stop it falling over on soft ground, but then as I recall it that was an issue anyway before I added the raising links.
#15 |
Keyboard Jockey
Locale: Tempe, AZ
Postings: 267
5'8 or so, I wear 29/30" inseams on jeans.. with my boots on I have 0 issues at all balancing it. I can even move it around.. given sometimes when backing up I have to bounce off the front brake, but thats it.
Bouncing off front brake: Hold front brake, push down on front suspension.. let off front brake, and then push the bike back with the front suspension's energy. SImple enough. |
#16 | |
Locale: Western, NC
Postings: 491
#17 | |
Locale: The Backwoods of Georgia
Postings: 1,819
3 KAWS in the Barn!!! 1999 KLR 250 - Teal? 2008 KLR 650 - Green 2001 Kawasaki ZG 1000 Concours - Black "Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure, or nothing." Helen Keller
#18 |
Super Cool Since: Sep 2003
Locale: Lost Wage$, NV
Postings: 13,858
how's the weather down there?
have you pulled your doohickey lately? KLR 650: Dirt Ninja • KLR 250: the ugly duckling, undergoing rehab ![]() √ote Libertarian! perpetuate the KLR stereotype, visit the Deals Forum
#19 |
Thanks for all the input guys, this is an AWESOME forum, BTW. It is totally killing me that I dont have the bike yet. I am going to take a class here in Calif to get my M1 license in a couple of weeks. Then if my employer will just give me a contract for more than 30 days at a time I am golden.
