Go Back   KLR650.NET Forums - Your Kawasaki KLR650 Resource! - The Original KLR650 Forum! > KLR650.NET - Kawasaki KLR650 Forums > 2008 through 2013 KLR650 Discussion
2008 through 2013 KLR650 Discussion The new, industry dominating second generation KLR650
Old 06-10-2010, 11:24 AM   #1
spikespiegel
spikespiegel's Avatar
Super Cool Since: Jan 2010
Locale: Folsom CA
Postings: 173
Default tightening up preload-how to
So i am finally thinking my rear sags too much on the bikes own weight, not including me sitting on the bike and this sometimes is an issue on tighter twisty turns where I start dragging pegs cause the rear squats.. I want to stiffen preload and possibly increase damping speed. I dont understand this non marked adjustment notion.. How do I know what setting I am in, and how do i know what setting i want to get it to... Is it a (cant move go clockwise) 1 2 3 4 5 (can't move go counter clockwise) sort of dealiyo?
spikespiegel is offline   Reply With Quote
Old 06-10-2010, 11:44 AM   #2
Steve
Super Cool Since: Sep 2005
Locale: N34°48.229' W82°43.200'
Postings: 948
Default Re: tightening up preload-how to
for the preload - get it up on a stand or something, at least remove as much of the weight off of the rear end as you can. it'll just make it move easier.
put a 12mm socket on the head of that bolt that is showing on the left-hand side of the rear shock. set your ratchet so that you're tightening a bolt <righty-tighty>. turn it and it'll click/clang up the steps as it goes to level 5. after that, it'll clang back to 1. as i recall, some of the New Gens had issues w that bolt breaking when folks went to adjust them. i dunno if/when that was remedied.
spray a quick shot of WD-40 into there before you start wrenching and it might help things loosen up a bit too.
sre
Steve is offline   Reply With Quote
Old 06-10-2010, 03:00 PM   #3
spikespiegel
Locale: Folsom CA
Postings: 173
thanks for the tip! Now, can i only go clockwise or can i go counter clock to losen preload?
Old 06-10-2010, 03:36 PM   #4
col. klink
col. klink's Avatar
Locale: North GA
Postings: 190
Spike, The first question is; how much do you weigh?
Taking all the weight off of the rear wheel will help you not break the adjuster bolt head.
....are you okay? that looked bad, I thought you said you could ride.
Kent Soignier
GMD Computrack Atlanta
279 Confederate Ave
Jasper, GA
706 253 1148
'08 KLR 650 (it's blue) new one piece third gear,
685cc kit and stage one head work.
parabellum windsheild, Garmin GPS 5 w/touratech mount.
RaceTech Cartridge Emulators and GoldValved shock/remote reservior, 400# spring.
15/38 gearing w/vortex alloy sprocket
michelin t63 tires
not enough time to ride.
col. klink is offline   Reply With Quote
Old 06-10-2010, 03:48 PM   #5
Steve
Postings: 948
Thumbs up Re: tightening up preload-how to
it only goes one way. when you go past the highest setting, #5, it will bang back down to #1.
and the colonel is on a good track. i ain't trying to help you determine where to set the preload, just telling you how to do it. ride on!
sre
Old 06-10-2010, 03:57 PM   #6
spikespiegel
Locale: Folsom CA
Postings: 173
i weigh 150 lbs without gear, with gear, probably 160 range... The bike sags quite a lot just under its own weight (even more so now than it did in day 1).. I also happen to go offroad in harsh stuff quite often... I'm thinking a little bit of preload tightening will help it tighten up sag... let me know if i'm on the right thought pattern
Old 06-10-2010, 04:19 PM   #7
col. klink
col. klink's Avatar
Locale: North GA
Postings: 190
Spike, yes I think you will benefit from more preload. A little.
I weigh 170 plus my gear. I run goldvalves from racetech (they're in your backyard) in my forks and shock. I rode like that on the stock spring for awhile.
then I put a spring on that is 400 pounds per inch, up from the stock 279 pounder.
That was a major improvement.
Kent Soignier
279 Confederate Ave
Jasper, GA
706 253 1148
michelin t63 tires
Old 06-10-2010, 04:54 PM   #8
spikespiegel
Locale: Folsom CA
Postings: 173
awesome, thanks for all the help guys. Last question, what setting is the bike set at stock off the showroom floor so I have a reference..
Old 06-10-2010, 09:12 PM   #9
John0270
John0270's Avatar
Locale: Sask, Canada
Postings: 1,320
You should see level marks as you go if you can't see any your probably at 1 or 2. You can turn backwards, instead of letting it slam back. Spray some sort of lubricant around the adjusting ring though, the 08's were on the week side. I had to fix mine as the ring gear retaining crimping just let it pop out, thankfully my gear didn't strip and all I had to do was disassemble the mechanism and crimp it back in.
90'000 km and counting 08 klr685.
John0270 is offline   Reply With Quote
Old 06-10-2010, 11:26 PM   #10
spikespiegel
Locale: Folsom CA
Postings: 173
mission successful! All the tips here, proping the rear up, spraying the collar/bolt and using the rachet was the key. Bike feels a lot better, way less squash and hopefully it'll be great when carving twisties n dirtin! Thanks guys
Old 06-13-2010, 02:22 AM   #11
spikespiegel
Locale: Folsom CA
Postings: 173
quick update after a solid ride today. Wow, what a difference with the proper preload on this bike.. In the dirt, even with 23F/27R tire pressures, the bike felt so much smoother and planted, I couldnt kick the back out even if I wanted to (almost).. Should have done this way back when I got the bike; i should know better, i got my suspension down to a science almost on my trackbike and I ignored it this long on the KLR! I can only imagine what a set of upgraded suspy bits will do to this bike
Old 07-23-2010, 02:35 PM   #12
sanfordturbo
sanfordturbo's Avatar
Super Cool Since: Feb 2008
Locale: Gainesville, GA
Postings: 45
What was your final setting that made you happy?
Standard preload position is 1 according to the service manual. I've got the same problem and thought I'd bump it up to a 3.
sanfordturbo is offline   Reply With Quote
Old 07-23-2010, 08:03 PM   #13
zt0117
zt0117's Avatar
Locale: Flagstaff, Arizona
Postings: 577
You'll be really happy when you put a Cogent Dynamics shock in it, and put some Ricor Intiminators in the forks
zt0117 is offline   Reply With Quote
Old 07-24-2010, 06:07 AM   #14
noobiesfest
On Vacation! :)
Super Cool Since: Jul 2010
Locale: Canada
Postings: 101
Not everyone has $700 to throw on a bike suspension. This is without taking into account the almost mandatory 685 kit the doo and all the other things this bike seems to need right out of the box to make it decent. After lurking into this forum for a while the more I think of it the more I believe this bike is not the right choice for me since most of my riding will be on paved roads and highway with the occasional stint on gravel roads. In about an hour i'm heading to the local Honda dealer and will take the Varadero 1000 for a free test drive as it is a special day today to drive the bike of your choice and they have a 2008 still in the crate. Suggested retail $14000 but with a markdown of 5000 from Honda it put this bike at $9000. A steal. I have heard that this bike is not available in the United States.
noobiesfest is offline   Reply With Quote
Old 07-24-2010, 09:34 AM   #15
zt0117
zt0117's Avatar
Postings: 577
The OP said he liked to ride hard in the dirt. I liked my KLR with the stock suspension, but like it more with the upgraded one. Is it an absolute necessity? No, but it is very nice. The Varadero looks like the equivalent of the V-Strom 1000, one of which I plan to get someday for adventure touring, but I'll be keeping the KLR for the more off-road type stuff.
Old 07-24-2010, 10:22 PM   #16
hoyks
Shhh...Dakar is on!!
hoyks's Avatar
Locale: SE Qld. (Australia)
Postings: 2,540
I used to ride mine with the preload on 5 but still had a bit of saggage, it didn't leave me any adjustment for when I added a load either.
I'm 6' 4" and 100kg and found the frame a little short, so I went the raising link option. They made it taller and stiffened up the suspension, so now I ride with it set on 1 and have the option of stiffening it up if I add a load.
hoyks is offline   Reply With Quote
Broken preload adjuster-I fixed it. John0270 2008 through 2013 KLR650 Discussion 4 07-06-2010 10:46 AM
RICOR Shock Preload Adjuster Flaw Gruf Rude KLR650 Main Discussion 8 11-07-2009 03:50 AM
Shock Preload Stuck-Help Old Blue Maintenance, Mods, & Tech 3 04-24-2008 03:40 PM
Preload and stepless rebound settings? Staalburger 2008 through 2013 KLR650 Discussion 7 03-10-2008 09:17 PM
?about the stock r.shock preload mechanism edhollyjenney Maintenance, Mods, & Tech 7 01-25-2007 02:26 PM
