Old 01-30-2012, 09:16 PM   #1
jeepsandbikes
Super Cool Since: May 2011
Locale: toronto
Postings: 319
jeepsandbikes is on a distinguished road
Default regulator /rectifier cooling mod
Since kawi decided to put the R/R in such a tight spot , i thought i would give it some cooling help . Ill see if this helps a bit in the summer . Plans are to upgrade to the new style R/R in the future .
120000 km and counting ..
jeepsandbikes is offline   Reply With Quote
Old 01-30-2012, 11:40 PM   #2
LocoPatrick
LocoPatrick's Avatar
Locale: Wellington, Colorado
Postings: 348
LocoPatrick is on a distinguished road
Default Re: regulator /rectifier cooling mod
Has regulator overheating been an issue? What problems have you seen, and what will tell you if the mod works?
"I was going faster than I ever went in my whole life, then I fell off."
"You came in that thing? You're braver than I thought!"
KLR650: The .30-06 of motorcycles.
LocoPatrick is offline   Reply With Quote
Old 01-31-2012, 04:56 AM   #3
gronk
Locale: South Oz
Postings: 321
gronk is on a distinguished road
I think I can remember reading of people relocating the R/R unit to the front of the bike, where it's more likely to get airflow. If you suspect you're having heat problems, that may be a simpler solution.
Good luck with your mod- I'm about to buy a new R/R because mine seems to be on the blink, so it's a good time to upgrade to a mosfet type unit.
G
gronk is offline   Reply With Quote
Old 01-31-2012, 08:09 AM   #4
willys
Rank: Expert
willys's Avatar
Locale: padded room
Postings: 12,162
willys is on a distinguished road
I wonder how long that pc fan will last after it gets wet in a rainy ride?
I relocated mine to out front, to each their own. If it works great idea.
willys is offline   Reply With Quote
Old 01-31-2012, 06:55 PM   #5
Mike Toon
Mike Toon's Avatar
Locale: Beautiful Downtown Burbank
Postings: 318
Mike Toon is on a distinguished road
Ill see if this helps a bit in the summer.
What kind of summer problems have you had?
`01 KLR
`02 KLR
`04 KLR
`02 CB919
-Burbank CA
Mike Toon is offline   Reply With Quote
Old 01-31-2012, 09:54 PM   #6
jeepsandbikes
Locale: toronto
Postings: 319
no problems with it really , just wanted to keep it cooler . they heat up and some people move them . i wanted to try this fan idea out ..
If the fan dies i have another ( and another and another ).. they only draw .1 amp to run too .
Old 01-31-2012, 10:22 PM   #7
jeffsaline
Locale: Rapid City, South Dakota
Postings: 7,822
jeffsaline has a spectacular aura aboutjeffsaline has a spectacular aura aboutjeffsaline has a spectacular aura about
What temp is it running at before and after the fan application?
At what ambient temperature?
What load on the charging system?
Just curious as to how you'll know if this is making a difference.
Jeff
Jeff Saline
Do Not Steal, Do Not Lie, Do Not Be Lazy
Good, Fast, Cheap - - - Pick Two
"Just because something isn't true, no reason you can't believe it." Hub McCann in Secondhand Lions
Anything is possible if you don't know what you are talking about.
jeffsaline is offline   Reply With Quote
Old 02-01-2012, 05:09 AM   #8
electroken
Super Cool Since: Mar 2007
Locale: Shelton, CT
Postings: 870
electroken is on a distinguished road
Do these things fail often?
I only ask because they're designed specifically to dissipate excess energy as heat. Hot to the human hand isn't all that hot.
electroken is offline   Reply With Quote
