Need Help Rebuilding Forks - KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum!
Go Back   KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum! > Other Kawasaki Motorcycles > KLR250 and Super Sherpa Main Discussion
Old 01-28-2017, 07:36 PM   #1
Prosie
Super Cool Since: Jan 2011
Postings: 13
Prosie is on a distinguished road
Default Need Help Rebuilding Forks
I have an '85 KLR 250 that I am rebuilding using a '90 parts bike.
I went to replace leaking oil seals and discovered stone nicks in the 85's forks. The 90's forks are smooth, but the bushings are shot.
I need to keep the damper rod from spinning so I can break loose the allen bolt at the bottom of the forks. As best as I can tell, the front axle nut (22mm) on the axle, a 22mm socket, and few extension make a good fit on the damper rod.
The problem is when I hold the damper rod with the 22mm nut & extensions and try to loosed the allen bolt the torque just loosens the nut on axle.
I figure either someone knows another way, or I need to get someone to weld a 22mm nut onto a T-handle.
Thoughts? This is my first time asking for help. I have found diligent searching has answered all my previous questions
Thanks, Prosie [ = Peter + Rosie: father/daughter KLR 250 riders & adventurers]
Prosie is offline   Reply With Quote
Old 01-28-2017, 09:57 PM   #2
NVGTI
NVGTI's Avatar
Locale: Dayton, NV
Postings: 2,673
NVGTI is on a distinguished road
Default Re: Need Help Rebuilding Forks
Try using two nuts and a washer between. Tighten the two nuts together and then try to use that to hold the inside of the damper rod.
Lynn
2008 Red KLR 650, T bob, CD Moab shock, Ricors up front, EM fork brace, KLR Dash, Seat Concepts, 35,000 miles
2007 Black, Ricor front/rear, EM fork brace, heated grips,
HT skid plate, Tusk foot pegs, SV650 front brake caliper, and 15,000 miles
1984 klr600; sold https://www.klr650.net/forums/showthread.php?t=105780
Insist on the best https://www.eagleMike.com/ or (619) two six one one two 8 1
NVGTI is offline   Reply With Quote
Old 02-06-2017, 03:05 PM   #3
littlejon
littlejon's Avatar
Super Cool Since: Mar 2007
Locale: Lofall, WA
Postings: 1,139
littlejon will become famous soon enough
you might try 7/8 nuts on all thread and file them down just a little to 22mm. (a belt sander, or grinder would be quick)
Use JB weld, if two nuts wont tighten together enough.
littlejon is offline   Reply With Quote
Old 02-13-2017, 10:15 AM   #4
Goofaroo
Super Cool Since: Mar 2014
Locale: Oklahoma
Postings: 52
Goofaroo is on a distinguished road
Use an impact wrench on the bolt on the bottom of the forks and it will pop right out. Use it again to reinstall but be careful not to over tighten. Then check it with a wrench. No special tools required to service these forks.
Goofaroo is offline   Reply With Quote
Old 05-22-2017, 09:31 AM   #5
thecrimsonking
thecrimsonking's Avatar
Super Cool Since: Mar 2012
Locale: argentina
Postings: 10
thecrimsonking is on a distinguished road
Hi I did that job last week, and I used the front wheel bolt to hold down whats inside the fork.
thecrimsonking is offline   Reply With Quote
forks, rebuilding
