Sub frame bent? - KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum!
Go Back   KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum! > Regional Events, Upcoming Rides & Tech Days > United States
> Alaska
Old 02-19-2011, 01:04 PM   #1
TeamGS
Super Cool Since: Feb 2011
Locale: Brewster,WA
Postings: 4
TeamGS is on a distinguished road
Default Sub frame bent?
Just purchased a 2005 KLR 650. While I was removing aftermarket exhaust to intsall OEM. I noticed the muffler pipe was making contact with the subframe where the passenger peg bolts up. I thought, well perhaps just aftermarket exhaust fitting issue.
Now I see that the OEM pipe hits the frame too. I did notice a scuff on the end of the passenger peg itself, nothing too severe, looks like damage from a fall over in a parking lot. Possibly this tip over bent the subframe in, the eyeball test doesn't appear that it is bent. But now I think it is. Could someone please check out this area on their bike and tell me how much clearance you have between the exhaust pipe and the tab in the subframe where the passenger peg bolts up.
Thanks.
TeamGS is offline   Reply With Quote
Old 02-19-2011, 01:14 PM   #2
klrAlaska
klrAlaska's Avatar
Locale: Anchorage,Alaska
Postings: 512
klrAlaska will become famous soon enough
Default Re: Sub frame bent?
Thanks.
GS: here are rough measurements on two bikes:
2005 with aftermarket exhaust: 5mm
2004 with stockk exhaust: 2mm
hope that helps
GS
'04 KLR650
'12 vStrom650
klrAlaska is offline   Reply With Quote
Old 02-19-2011, 01:22 PM   #3
TeamGS
Locale: Brewster,WA
Postings: 4
Yes, that helps me! Looks like your info confirms mine was bent in a bit, now I need to figure out a way to pull it back out.
Thanks so much.
Old 02-19-2011, 10:54 PM   #4
monkeymind
monkeymind's Avatar
Super Cool Since: Nov 2010
Locale: Clatskanie, Oregon
Postings: 687
monkeymind is on a distinguished road
What'cha doing with the after market muffler?
monkeymind is offline   Reply With Quote
Old 02-20-2011, 12:46 AM   #5
TeamGS
Locale: Brewster,WA
Postings: 4
I am going to sell it.
It has under 100 miles of use; Big Gun Evo X (first generation I think its the X) with header pipe.
Old 02-20-2011, 05:53 PM   #6
monkeymind
monkeymind's Avatar
Postings: 687
Those are pretty loud aren't they?
Old 02-20-2011, 07:33 PM   #7
TeamGS
Locale: Brewster,WA
Postings: 4
Ya know to be honest I never even started the bike with it installed! The bike had been sitting for a couple of years in the PO garage so... dead battery, old gas etc.
I have read that they are pretty loud.
Old 02-20-2011, 09:31 PM   #8
klrAlaska
klrAlaska's Avatar
Postings: 512
Big Gun Evo X
That is the same one that's on my sons bike (that I measured for you.) It is too loud for my taste. I can be 1/4 mile or more behind him and know exactly when he's twisting the throttle. He's got a removable baffle or something he puts in it and then it's not too bad though.
GS
'04 KLR650
'12 vStrom650
bent, frame
Bent frame? [TASF]Overkill KLR250 and Super Sherpa Main Discussion 4 05-04-2009 05:01 PM
Bent Frame ? waco54sp KLR650 First Generation 15 10-27-2008 09:51 PM
My Mermite Can and frame mount Project crosscountry KLR650 Maintenance, Modifications & Technical 3 06-03-2008 12:25 AM
First Farkles - LED Taillight, Move License Plate, LED Frame ramblin66 KLR650 Maintenance, Modifications & Technical 1 12-30-2007 09:35 PM
Wrecked 03 bent frame, forks $1500 Scott_Rides_Again KLR650 First Generation 9 06-16-2007 12:53 PM
