Gen 1 Front Wheel on a Gen 2 ? - KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum!
Go Back   KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum! > KLR650 Discussion Forums > KLR650 Maintenance, Modifications & Technical
KLR650 Maintenance, Modifications & Technical Wrenching and mods - KLR650 Technical discussion only!
Old 04-28-2017, 05:03 PM   #1
Stew2
Super Cool Since: Dec 2012
Locale: Utah
Postings: 21
Stew2 is on a distinguished road
Default Gen 1 Front Wheel on a Gen 2 ?
I was going to change the wheel bearings on my 08 and when I took off the speedometer drive cover I saw that the outer rim of the hub had broken off and and the pieces were in the speedo cover. I guess I need a new wheel? I'm wondering if a gen 1 wheel will fit on the 2nd gen. Can I switch over rotors?
Stew2 is offline   Reply With Quote
Old 04-28-2017, 05:51 PM   #2
jeffsaline
Locale: Rapid City, South Dakota
Postings: 9,363
jeffsaline is a jewel in the roughjeffsaline is a jewel in the roughjeffsaline is a jewel in the roughjeffsaline is a jewel in the rough
Default Re: Gen 1 Front Wheel on a Gen 2 ?
Speedo Hub Wattman Tool. See post #12 of this thread.
https://www.klr650.net/forums/showthread.php?t=116915
Jeff
Jeff Saline
Do Not Steal, Do Not Lie, Do Not Be Lazy
"Just because something isn't true, no reason you can't believe it." Hub McCann in Secondhand Lions
"If you don't have a time table you can't be late. When you don't have a destination you can't get lost." Colin Stafford-Johnson, Ireland's Wild Coast
jeffsaline is offline   Reply With Quote
Old 04-28-2017, 06:09 PM   #3
azklrian
Locale: AZ/AB
Postings: 461
azklrian is on a distinguished road
Gen1 front wheel will work fine on a gen2 if you change the brake rotor.
azklrian is offline   Reply With Quote
front, gen, wheel
