needs carb work - KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum!
Go Back   KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum! > Other Kawasaki Motorcycles > KLX Main Discussion
KLX Main Discussion KLX650, KLX400, KLX300, KLX250S, KLX125
Old 10-04-2017, 08:17 PM   #1
DS Cowboy
DS Cowboy's Avatar
Super Cool Since: May 2010
Locale: Eastern NC
Postings: 228
DS Cowboy is on a distinguished road
Default needs carb work
I have an 09 KLX250s that's been sitting for 2 years. I drained the tank and pulled the carb to get all the gas out and put it back together. It would not fire. I took the air cleaner out and and sprayed a bit of carb cleaner in and it fired right up. Stays running as long as you spray. So it looks like the carb has to come off again. Is there a short cut, like a most common place to clean/spray? Must you do a total rebuild? Just pull the jets and spray out?? What do you think?
09 KLR650
Uni, KLX needle, 140M, 2 turns
09 KLX250s
Uni
DS Cowboy is offline   Reply With Quote
Old 10-05-2017, 08:56 AM   #2
JeffsDarkSide
Wait, what?
JeffsDarkSide's Avatar
Super Cool Since: Apr 2012
Locale: LA / NGA
Postings: 1,815
JeffsDarkSide has a spectacular aura aboutJeffsDarkSide has a spectacular aura aboutJeffsDarkSide has a spectacular aura about
Default Re: needs carb work
No shortcut after sitting for 2 years. I would disassemble the whole carb and either soak it or get it get it ultrasonically cleaned. I would also just buy new jets since they are cheap and yours sound either totally blocked or really crudded up. After all that chase every orifice/passage with carb cleaner and compressed air to confirm they are clear. Don't forget to inspect any gaskets and rubber parts for cracks, holes or decay.
2012 black KLR650
2007 black KLR650
JeffsDarkSide is offline   Reply With Quote
Old 10-05-2017, 11:37 AM   #3
DS Cowboy
DS Cowboy's Avatar
Locale: Eastern NC
Postings: 228
Thanks JeffsDarkSide. I felt like that would have to be done. Just didn't want to face it! Got to do the same thing for the KLR650. Getting them ready to sell.
09 KLR650
09 KLX250s
Uni
Old 10-05-2017, 03:20 PM   #4
JeffsDarkSide
Wait, what?
Locale: LA / NGA
Postings: 1,815
Denial is a wonderful thing..........unless your bike isn't running!!
I hope you are still going to be riding something since you are in such a beautiful part of the country. Nothing better than the TN, GA and NC areas of the Appalachians IMHO!!
2012 black KLR650
2007 black KLR650
Old 10-05-2017, 05:33 PM   #5
DS Cowboy
DS Cowboy's Avatar
Locale: Eastern NC
Postings: 228
The app's are indeed a great place. My wife and I stayed at Crawford's Campground for a long weekend a few years ago and had a really great time. I don't have immediate plans but one day I'd love to get a twin of some kind. I like the thought of the Yamaha.
09 KLR650
09 KLX250s
Uni
Old 10-28-2017, 05:39 PM   #6
DS Cowboy
DS Cowboy's Avatar
Locale: Eastern NC
Postings: 228
Okay I think I have everything cleaned except the pilot jet. Does anyone know what the hole diameter should be? I can see some daylight through it but I do see some trash also. I tried the smallest torch tip cleaner that I have and it does not fit. I also tried some very thin piano wire for hanging pictures and it does not fit.
09 KLR650
09 KLX250s
Uni
Old 10-28-2017, 06:51 PM   #7
JeffsDarkSide
Wait, what?
Locale: LA / NGA
Postings: 1,815
No idea but OEM jets are cheap or you could search your nearest welding supply store for some tip cleaners..............HD or Lowes should have them too.
2012 black KLR650
2007 black KLR650
Old 10-29-2017, 12:21 AM   #8
DS Cowboy
DS Cowboy's Avatar
Locale: Eastern NC
Postings: 228
I have that exact set. Thanks though. I'll give it one more soak and clean and if it doesn't work I'll get a new one. Appreciate the input!
09 KLR650
09 KLX250s
Uni
Old 11-02-2017, 08:20 PM   #9
DS Cowboy
DS Cowboy's Avatar
Locale: Eastern NC
Postings: 228
Purrrrring like a kitten!!!
09 KLR650
09 KLX250s
Uni
carb, work
03 KLR fuelling issues - started work on it Korruptor KLR650 Maintenance, Modifications & Technical 13 05-04-2017 08:53 AM
Slow stall after getting up to temp. Carb issue? Oscarunnatural KLR650 Maintenance, Modifications & Technical 32 04-21-2016 02:47 AM
Never touched a carb in my life. Did the KLX needle, and... RichardBronosky KLR650 Maintenance, Modifications & Technical 9 04-15-2016 06:13 PM
Carb / Fuelling issue I can't resolve tenkasen KLR650 Maintenance, Modifications & Technical 6 12-29-2015 01:40 PM
Carb install on 2009 - did I do it right? Real worried. UgleeX KLR650 Maintenance, Modifications & Technical 27 11-20-2015 04:09 PM
