Eagle Mike's and Sams 762 Stroker kit! - Page 2 - KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum!
Go Back   KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum! > Premium Advertisers > Eagle Mfg & Eng
Eagle Mfg & Eng Click the banner to purchase! QUALITY. MADE IN USA! Forum operated by Eaglemike
Old 09-06-2017, 04:38 PM   #21
Eaglemike
Locale: San Diego
Postings: 9,456
Eaglemike has much to be proud ofEaglemike has much to be proud ofEaglemike has much to be proud ofEaglemike has much to be proud ofEaglemike has much to be proud ofEaglemike has much to be proud ofEaglemike has much to be proud ofEaglemike has much to be proud of
Default Re: Eagle Mike's and Sams 762 Stroker kit!
A few have asked about stroke to rod length ratio. It's good, no worries, can you say 1.6?
It's a straight bolt in to standard cases. This was my design requirement. No spacer needed. You can still work on the bike as easily as it is when stock. This was a design requirement.
We are running a different carb, that will bolt in when we add a couple of parts I make for it. No frame cutting. This was also a design requirement. We'll have a kit with cables, jetted, ready to go, brand new carb, for about $430 plus shipping. Will also work on stock engine KLR, slightly different jetting.
Right now we are running stock camshafts, but have more ready for testing when the dyno is up and running. I'm hoping to have it running for tech day.
Eagle Mfg & Eng since 1990 - Insist on genuine Eagle parts!
https://eaglemike.com/ for parts.
Cary Aspy -the real klr650 guru. RIP my brother, I miss you.
Don't try to be a great man, just be a man, and let history make it's own decision
Be your own KLR650 GURU!
Eaglemike is online now   Reply With Quote
Old 09-22-2017, 04:07 PM   #22
srech77
Super Cool Since: Sep 2017
Locale: Billings, MT
Postings: 5
srech77 is on a distinguished road
I was just about to go after the 685 or 705 kit this winter ... I may have to wait and reconsider. This is awesome..
srech77 is offline   Reply With Quote
Old 09-24-2017, 10:36 AM   #23
srech77
Postings: 5
So this would be Gen I applicable only, correct?
Old 09-24-2017, 11:23 AM   #24
Postings: 18,687
If you are referencing stroker engine...any Gen1 or Gen2 engine. Post 95 engines would need a different (later model) cylinder. If you are referencing different carb...any Gen1 or Gen2.
Chuck B is offline   Reply With Quote
Old 09-24-2017, 12:45 PM   #25
srech77
Postings: 5
Yes, sorry I should have been more specific - I have a 2015 KLR, and I noticed early in this post it referenced something about a Gen I. And I'm relatively new to the KLR so I'm not sure how "interchangeable" parts on the motors are between the different generations.
I'm referring to whatever would be necessary to outfit a 2015 model with the 762 stroker kit, i.e. Crank, rod, piston, jug, head, cams, carb, etc...
But thank you for clarifying 👍🏼
Old 09-24-2017, 03:48 PM   #26
AZSpeedfreek
Postings: 569
AZSpeedfreek is on a distinguished road
I have a credit card and then voices in my head said I should do this once it is available so.....
How much and when is/will it be available???
Mike...
Is/will the stroker be ok to run with stock gearing at 75-85mph??
AZSpeedfreek is offline   Reply With Quote
Old 09-25-2017, 01:21 PM   #27
Eaglemike
Locale: San Diego
Postings: 9,456
Easiest to build using a 1996/later engine. Earlier engines ok, but clutch and output shaft not as friendly, output shaft no longer available.
Any year engine CAN be used.
Stock gearing will work fine, but it will feel like it's geared pretty short. We've tested all the way up to 17/34. It has enough power to pull it, but a little tall around town. Awesome on the freeway. Current gearing is 14/34, fun and fine. Very freeway friendly, and works around town. Even with 17/34 wheelies are pretty easy. This is with stock camshafts. We have custom camshafts were will be testing soon.
We are still refining what it's going to cost. Most would be labor. My guesstimeate this minute would be around $2500, including carb and the engine work. Might be able to get it lower, but we'll see......
Top speed is limited by wobble right now. With the stock body work it gets squirrely about 125 indicated.......... Still accelerating fairly well at that speed. We are running fat tires, going to go back to stock on the next one to reduce drag and see what that does.
Old 09-25-2017, 01:33 PM   #28
mxh
mxh's Avatar
Super Cool Since: Aug 2010
Locale: Manitoba, Canada
Postings: 85
mxh is on a distinguished road
Best guess on when you'll be able to take orders and do the work?
Thanks,
2010 KLR 685 stage II
mxh is offline   Reply With Quote
Old 09-25-2017, 02:49 PM   #29
Eaglemike
Locale: San Diego
Postings: 9,456
Thanks,
safe to say about 3 months. After we proof the 4 pistons in hand, we'll order a production batch. Those take about a month to 6 weeks. We have the rods already. Just want to double and triple check everything.
Old 11-11-2017, 10:48 PM   #30
rfarmer2
Super Cool Since: Feb 2015
Locale: Arkansas
Postings: 1
rfarmer2 is on a distinguished road
Any updates on this? Seriously will keep me from going back to an orange bike that has left me stranded on the side of the road several times. Would love to have the power to keep me from doing that
rfarmer2 is offline   Reply With Quote
Old 11-13-2017, 11:40 AM   #31
KLdrumR
Dig it
KLdrumR's Avatar
Super Cool Since: Apr 2007
Locale: Merrimack Valley MA
Postings: 7,704
KLdrumR is on a distinguished road
I missed this thread until just now.
pretty wild!
I just wish one of us who is no longer with us could be around - I'm sure he'd be deeply involved.
Speed King
KLdrumR is offline   Reply With Quote
Old 11-15-2017, 08:33 PM   #32
Pollack
Pollack's Avatar
Super Cool Since: Jun 2014
Locale: In Transit
Postings: 355
Pollack is on a distinguished road
A 34 tooth rear sprocket is not a typo is it.......
Best regards,
2013 KLR - 29K
Pollack is offline   Reply With Quote
Old 11-18-2017, 12:30 PM   #33
Eaglemike
Locale: San Diego
Postings: 9,456
Best regards,
Not a typo.......
Old 12-08-2017, 01:54 AM   #34
AZSpeedfreek
Postings: 569
Crazy question for you Mike... If the 762 stroker was installed on a Gen1 motor that happened to have a kickstarter installed on it... what are the odds of it being able to be started with a kickstarter?
Old 12-08-2017, 10:04 AM   #35
Eaglemike
Locale: San Diego
Postings: 9,456
I think it would work. We are not running a lot of extra compression. Right now we are running stock camshafts.
I've not personally played with a klr with kickstarter, but if everything was in good shape, don't see a problem.
Old 12-08-2017, 10:15 PM   #36
Postings: 18,687
If you want a kick starter...buy a Honda XR650R. That should teach you! lol
Old 12-08-2017, 10:30 PM   #37
AZSpeedfreek
Postings: 569
Kick starter is for back up (and I already have it), my Gen1 build plans are to make this thing as solid and bullet proof as possible.
Old 12-08-2017, 11:50 PM   #38
skypupbob
Super Cool Since: Jan 2009
Locale: boise idaho
Postings: 108
skypupbob is on a distinguished road
Yes ,I had one once ,I like the button.
skypupbob is offline   Reply With Quote
762, eagle, kit, mike, sams, stroker
