Parting out nice 2005 KLR650 - Page 4 - KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum!
Go Back   KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum! > Classifieds & Deals > KLR650 Parting out
KLR650 Parting out Paid classifieds only.
Old 07-02-2017, 12:01 AM   #61
battery
Super Cool Since: Jun 2004
Locale: Northeast Iowa
Postings: 415
battery is on a distinguished road
Default Re: Parting out nice 2005 KLR650
Originally Posted by AZ67 View Post
Do you have the bracket that the cowling attaches to?
Thank you!
Eric
Nope, sold
2005 DRZ400S K5
1989 KDX200 E1
2000 ZR-7 F2
Lots of 2005 KLR650 parts!
battery is offline   Reply With Quote
Old 07-16-2017, 11:29 PM   #62
Granteezie
Granteezie's Avatar
Locale: Camano Island, Wa
Postings: 2,156
Granteezie is on a distinguished road
Originally Posted by battery View Post
*Starter Motor - $50 + postage, good shape
*Header Pipe - $50 + postage, Good condition
*Tail Light Fixture - $40 + postage, Includes Bulb, stock wiring
*Speedo Gears for front wheel - $30 + postage
*Front brake Master Cylinder, Perch, and OEM lever - $40 + postage
*Front Caliper - $50 + postage, with like new EBC Sintered Pads (1700 miles on them)
*Rear Brake Master Cylinder Assembly - $40 + postage, Includes M/C, reservoir, and tubing.
*Rear Caliper - $40 + postage, Includes EBC Sintered pads at about 75%
*Rear Caliper Mounting Bracket - $25 + postage
*Rear Brake Light Switch - $20 + postage, includes spring
*Rear Plate Lamp - $20 + postage
*Battery Lead (+) - $15 + postage
*Battery Lead (-) - $15 + postage
*Starter Lead - $20 + postage
*Solenoid - $10 + postage
*Rear swingarm adjusters and caps - $20 for the pair + postage
*Rear Swingarm sliding adjustment indicators - $15 for the pair + postage
*Stock Tool Box - $15 + postage
* Instrument panel / speedometer /odometer/ trip meter / tachometer assembly. $110 + postage. 41K on the ticker. Looks and works great.
* Instrument panel mounting bracket / connector holder. $20 + postage
* Right hand "kill" switch - $25 + postage
* Clutch perch assembly, with OEM lever, adjuster wheel, and safety switch. $30 + postage
* Voltage Regulator – OEM. $50 + postage.
* Waterpump Cover - $20 + postage. Good, clean gasket surface, no corrosion inside.
* Battery – Sealed, BikeMaster brand - $35 + postage. Model #BTX14AHL-BS. Used only 1 season (5 months)
*Headlamp Fixture. Includes lens, good bulb, and bracket assembly. $40 + postage.
*Inner Shroud – rear of cowling - $20 +postage. Incl. 12v outlet if you want it. Kaw. PN: 14024-1366 (see pics)
*Rear Brake Pedal - $50. + postage. Like new, includes return spring and mounting shaft.
*Choke Cable w/ choke lever mechanism - $20 + Postage. Like new, "Motion Pro", used less than one season.
*Front Axle w/ washer & nut. - $20 + postage
*Rear Axle w/ washer & nut - $20 + postage
*Cylinder & Sleeve: $120 + postage. Inner sleeve is in great condition.
*Bolts – Head/Cylinder (4): $20 + postage
*Tensioner – Timing Chain $25 + postage. Excellent condition
*Oil distribution tube – head; $20 + postage.
*Rotor Assembly: $120 + postage
*Stator: $60 + postage
*Stator Cover – LH Outer: $50 + postage
*Stator Cover – LH Inner: $35 + postage
*“C-Mark” Rotor Gear: $100 + Postage
*Gear Spur – 20/37 tooth - $40 + postage, Kaw. part number: 59051-1133
*Limiter - $40 + postage. Kaw. part number: 39076-1056
*Clutch Assembly: $140 + postage. Newer EBC plates and springs (1700 miles). OEM Basket and steel plates.
*Bracket – RHS Coolant Resv. & Electrical: $30 + postage. Kaw part number: 35011-1370
*Coolant Resevoir Bottle: $20 + postage. Includes tubing.
*Bracket: RHS Inner electrical: $20 + postage. Kaw. part number: 11045-1358
*Cover – RHS Cooling Resv & Electrical: $20 + postage. Kaw. part number: 14024-1372
*Horn: $15 + postage
*Igniter: $ 120 + Postage
*Full Electrical Harness: $40 + postage
*Swing arm: $100 + postage. Has a few scratches, normal wear and tear, fully functional.
*Raising Links; RL-1: $15 + postage. Early Eagle MFG prototype but they work great!
*Lower Linkage assembly: $30 + postage
*Swingarm pivot bolt: $20 + postage. Includes Nut & Washer
I'll take the solenoid if its still available. Shipped to 98282.
Granteezie is offline   Reply With Quote
Old 07-18-2017, 10:58 PM   #63
Glenn
Site Administrator
Glenn's Avatar
Super Cool Since: Jun 2003
Locale: USA
Postings: 18,636
Glenn has much to be proud ofGlenn has much to be proud ofGlenn has much to be proud ofGlenn has much to be proud ofGlenn has much to be proud ofGlenn has much to be proud ofGlenn has much to be proud ofGlenn has much to be proud of
Please post an updated list of the parts you have available.
Glenn is offline   Reply With Quote
Old 07-19-2017, 11:50 PM   #64
battery
Postings: 415
*Triple Trees w/bearings - $40 + postage, Good Condition. I think the existing bearings can be re-used.
*Header Pipe - $20 + postage, Good condition
*Front Axle w/ washer & nut. - $10 + postage
*Rear Caliper Mounting Bracket - $20 + postage
*Rear Brake Light Switch - $15 + postage, Includes spring
*Headlamp Fixture. Includes lens, good bulb, and bracket assembly. $30 + postage.
*Voltage Regulator – OEM. $30 + postage.
*Starter Lead - $15 + postage
*Starter Motor - $35 + postage, good shape
*Rotor Assembly: $50 + postage
*“C-Mark” Rotor Gear: $40 + Postage
* Waterpump Cover - $15 + postage. Good, clean gasket surface, no corrosion inside.
*Gear Spur – 20/37 tooth - $25 + postage, Kaw. part number: 59051-1133
*Limiter - $25 + postage. Kaw. part number: 39076-1056
*Tensioner – Timing Chain: $25 + postage. Excellent condition
*Swing arm: $50 + postage. Has a few scratches, normal wear and tear, fully functional.
*Swingarm pivot bolt: $10 + postage. Includes Nut & Washer
*Rear Swingarm sliding adjustment indicators - $10 for the pair + postage
*Lower Linkage assembly: $20 + postage (minus the links)
*Bracket – RHS Coolant Reservoir & Electrical: $15 + postage. Kaw part number: 35011-1370
*Upper Motor Mount - $15 + postage, Includes 3 bolts
*Front Motor Mount - $15 + postage, Includes 3 bolts
*Bracket: RHS Inner electrical: $15 + postage. Kaw. part number: 11045-1358
*Cover – RHS Cooling Resv & Electrical: $15 + postage. Kaw. part number: 14024-1372
*Shift Shaft (Inner) - $25 + postage. Like new, replaced in 2016. Splines are like new!
2005 DRZ400S K5
1989 KDX200 E1
2000 ZR-7 F2
Old 09-05-2017, 11:59 PM   #65
pbrokaw
Super Cool Since: Aug 2017
Locale: Tacoma WA
Postings: 7
pbrokaw is on a distinguished road
Speedo front wheel drive thingy to Tacoma WA 98409.
Thanks'
Perry Brokaw
pbrokaw is offline   Reply With Quote
Old 09-12-2017, 11:36 PM   #66
MatBirch
Super Cool Since: May 2017
Locale: Whatcom County Washington
Postings: 37
MatBirch is on a distinguished road
Rear shock linkage shipped to 98266??
Thanks!
MatBirch is offline   Reply With Quote
Old 09-16-2017, 06:06 PM   #67
battery
Postings: 415
Thanks!
PM sent
2005 DRZ400S K5
1989 KDX200 E1
2000 ZR-7 F2
Old 11-22-2017, 10:19 AM   #68
Kawahawki
Super Cool Since: Sep 2016
Locale: North Liberty, IA
Postings: 14
Kawahawki is on a distinguished road
Still have those wheels for sale?
Kawahawki is offline   Reply With Quote
Old 11-23-2017, 11:30 PM   #69
snake89
snake89's Avatar
Super Cool Since: Dec 2014
Locale: Memphis Tn. unfortunately
Postings: 14
snake89 is on a distinguished road
Rear shock ???
I can always beat the paramedics to my crashes by at least 10 minutes !!!
snake89 is offline   Reply With Quote
Old 11-24-2017, 12:52 AM   #70
battery
Postings: 415
Sorry, shock and wheels are sold. See the following list:
*Triple Trees w/bearings - $35 + postage, Good Condition. I think the existing bearings can be re-used.
*Voltage Regulator – OEM. $15 + postage.
*Inner Shroud – rear of cowling - $15 +postage. Kaw. PN: 14024-1366
*Rotor Assembly: $40 + postage
*“C-Mark” Rotor Gear: $20 + Postage
*Bolts – Head/Cylinder (4): $15 + postage
*Tensioner – Timing Chain: $20 + postage. Excellent condition
*Oil distribution tube – head; $15 + postage.
*Swing arm: $35 + postage. Has a few scratches, normal wear and tear, fully functional.
*Lower Linkage assembly: $15 + postage (minus the links)
2005 DRZ400S K5
1989 KDX200 E1
2000 ZR-7 F2
2005, klr650, nice, parting
HTML code is On
