Potential ticking time bomb caught! - Page 4 - KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum!
Old 02-01-2010, 08:21 PM   #61
ginn68
ginn68's Avatar
Locale: Fuquay Varina, NC
Postings: 33
ginn68 is on a distinguished road
Default Re: Potential ticking time bomb caught!
Has anyone seen in failures? I assume that's what Kawi will look at for a recall.
This is a major issue to add to the other open issues (i.e. oil burning, doo's, rubber, blinkers, and wiring harness) Fun stuff....I still wouldn't trade my KLR for anything.
ginn68 is offline   Reply With Quote
Old 02-04-2010, 07:43 PM   #62
bfine
bfine's Avatar
Postings: 343
bfine is on a distinguished road
I consider my first find a failure, the other preventing a catascopic failure
bfine is offline   Reply With Quote
Old 03-27-2010, 06:13 PM   #63
rustynut
rustynut's Avatar
Locale: Belleville, IL
Postings: 1,235
rustynut is on a distinguished road
I just found this issue on my 09
Work harder, millions on welfare depend on you.
12 Tiger 800xc
09 KLR 650
rustynut is offline   Reply With Quote
Old 03-27-2010, 06:27 PM   #64
rustynut
rustynut's Avatar
Postings: 1,235
Can anyone suggest what I should do. I found it by accident, searching for a lost shim from my first valve job. A special thanks to Yarddog for providing his knowledge and spare shims.
So should I talk to my dealer or make a shim?
Click image for larger version
ID:	29587  Click image for larger version
12 Tiger 800xc
09 KLR 650
Old 03-27-2010, 06:51 PM   #65
A9-NM
Super Cool Since: Mar 2009
Locale: NM
Postings: 409
A9-NM is on a distinguished road
Pull the gear out and take a pic of the other side and the cover.
A9-NM is offline   Reply With Quote
Old 03-27-2010, 06:55 PM   #66
rustynut
rustynut's Avatar
Postings: 1,235
In the first pic that is the cover with the never ending hole. The engine side is fine, the shaft fits and stops where it should, the cover side the shaft goes in way to far.
12 Tiger 800xc
09 KLR 650
Old 03-27-2010, 07:13 PM   #67
A9-NM
Locale: NM
Postings: 409
Get a new side cover if the dealer will cough one up for free. Otherwise make a plug. BTW where is the other shim washer?
Old 03-27-2010, 07:17 PM   #68
rustynut
rustynut's Avatar
Postings: 1,235
One on either side of the gear right???
12 Tiger 800xc
09 KLR 650
Old 03-27-2010, 07:20 PM   #69
A9-NM
Locale: NM
Postings: 409
yes
Old 03-27-2010, 07:27 PM   #70
hoyks
hoyks's Avatar
Locale: SE Qld. (Australia)
Postings: 2,717
hoyks is on a distinguished road
I had the same on mine, the shaft had moved so far outboard that it was no longer supported on the engine side as can be seen by the gouging near the bush on the engine side.
I pulled the bearing bush in the outer case, fitted a 1/4" spacer into the case with a stainless washer on the shaft side and reinstalled the bush. Once fitted, the bush will stop the spacer and washer going anywhere and stops the shaft migrating outboard.
hoyks is offline   Reply With Quote
Old 03-27-2010, 08:01 PM   #71
rustynut
rustynut's Avatar
Postings: 1,235
Thanks Hoyks, if its not worth a trip to the dealer then I need some measurements. OD and Length of a shim. But if its a known problem then lets get them to address it. EM, WW many others I'm sure, what to do.....
12 Tiger 800xc
09 KLR 650
Old 03-27-2010, 09:31 PM   #72
hoyks
hoyks's Avatar
Postings: 2,717
I think it has been addressed in later built bikes, the hole isn't bored as deep.
I just couldn't be bothered going into the dealer. It is too far, ends up as an argument and I leave fuming. I just get on with it.
Old 03-27-2010, 09:59 PM   #73
rustynut
rustynut's Avatar
Postings: 1,235
I know your point, it just doesn't sit well with me. A problem that they just let go...
I would like some proper mesurements if they are available, please.
12 Tiger 800xc
09 KLR 650
Old 03-27-2010, 10:34 PM   #74
Yard Dog
Yard Dog's Avatar
Super Cool Since: Jun 2004
Locale: Pine Lawn Missouri
Postings: 2,281
Yard Dog is on a distinguished road
Glad I could help. It wouldn't hurt to discuss it with the service manager at the selling dealer. I e mailed you. Ken
Suffers from Multi KLR Disorder
Yard Dog is offline   Reply With Quote
Old 03-28-2010, 01:14 AM   #75
PKZZR
PKZZR's Avatar
Locale: New Oxford, PA
Postings: 121
PKZZR is on a distinguished road
What was your date of manufacture? Trying to determine if my 09 may have the same issue without pulling the cover.
2005 Kawasaki ZZR 1200
2009 Kawasaki KLR 650 BLUE#11
PKZZR is offline   Reply With Quote
Old 03-28-2010, 03:49 AM   #76
hoyks
hoyks's Avatar
Postings: 2,717
I used a aluminium standoff spacer (ally rod with a 5/32 hole up the middle) I had in the shed.
It was 3/8" wide x 1/4" and backed up with a 1/32" thick washer. Not certain on the washer size but it must be around the 3/8 - 1/2" mark. I just grabbed it out of the bits box and didn't pay that much attention.
Old 03-28-2010, 08:12 AM   #77
rustynut
rustynut's Avatar
Postings: 1,235
8/08
12 Tiger 800xc
09 KLR 650
Old 03-28-2010, 09:35 AM   #78
PKZZR
PKZZR's Avatar
Postings: 121
8/08
Mine was 10/08, too close not to pull the cover again (1st time doo) and check. My 12 months was up in December so I'll be making a spacer if it is a deep hole. Thanks.
Old 03-28-2010, 10:28 AM   #79
rustynut
rustynut's Avatar
Postings: 1,235
I did the doo also and didn't see it. I guess I was lucky to drop a shim in the abyss while doing a valve shim job.
12 Tiger 800xc
09 KLR 650
Old 04-26-2010, 09:50 PM   #80
bfine
bfine's Avatar
Postings: 343
Just a friendly reminder to check your hole!
bomb, caught, potential, ticking, time
