Valve Shim Swap ? - Page 5 - KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum!
Old 06-17-2013, 10:20 PM   #81
jeff488
Super Cool Since: Jun 2011
Locale: Nacogdoches, TX
Postings: 179
jeff488 is on a distinguished road
Default Re: Valve Shim Swap ?
I have:
260 - 3 each
265 - 5 each
270 - 2 each
I need:
235 - 1
240 - 2
245 - 2
250 - 1
I'll trade all 10 of mine for the 6 I need.
'04 BMW R1150RT, silver
'08 Suzuki Weestrom, yellow
I just want somewhere to ride and food when I get there.
jeff488 is offline   Reply With Quote
Old 12-14-2013, 01:09 AM   #82
slawson2000
slawson2000's Avatar
Super Cool Since: May 2012
Locale: Las Vegas, NV / Pine Grove, CA
Postings: 750
slawson2000 is on a distinguished road
Looking for a pair of 2.25's, would probably have a 2.50 left over. Please PM me if you can help.
slawson2000 is offline   Reply With Quote
Old 04-13-2014, 12:03 PM   #83
BAMBAM650
Locale: Cincinnati, OH
Postings: 782
BAMBAM650 is on a distinguished road
I have: (2) - 2.65 and (2) - 2.55 OEM shims.
Looking for: (2) - 2.55; (1) - 2.45; and (1) - 2.40.
BamBam650 - 2008 Red (now black) KLR with too many farkles and mods to mention.
BAMBAM650 is offline   Reply With Quote
Old 04-14-2014, 01:04 PM   #84
Norm
Norm's Avatar
Super Cool Since: Aug 2005
Locale: Chilliwack, BC, Canada
Postings: 1,891
Norm is on a distinguished road
The black coating may be a moly or other surface coat to assist with initial wear in of the shim to cam lobe. New cams often have a coating and we used cam lube when installing camshafts regardless of new or reinstall. I always put a dab on the cam journals and lobes when doing a valve adjustment. A small bottle of cam assembly lube lasts for a long time when doing V8's and mine is more than a decade old 'cause only doing bikes.
I'd want to know for certain what was that coating before using some abrasive to remove. If had to guess, I'd leave it alone.
HIH
Norm
Norm is offline   Reply With Quote
Old 05-24-2014, 05:15 PM   #85
Norton 850
Norton 850's Avatar
Super Cool Since: Mar 2010
Locale: Houston, Texas
Postings: 1,422
Norton 850 is a jewel in the roughNorton 850 is a jewel in the roughNorton 850 is a jewel in the rough
I often "make" my own shims.
It's easy to do if you have a belt sander, a thick piece of glass, 320 grit sand paper and an accurate OD micrometer. I use the belt sander to reduce the shim to within about 0.003" of the thickness I need. I take it slow with lots of measuring to ensure the surfaces remain parallel.
Then I lay a sheet of 320 grit wet/dry sandpaper on my plate of glass and "sand" the shim to final thickness using WD 40 to float away the cuttings. Again taking lots of measurements. The surface finish appears to be at least 16RMS when I get through sanding (polished), but I position the newly polished side of the shim down into the bucket and let the cam ride on the virgin side of the shim.
Norton 850 is offline   Reply With Quote
Old 09-27-2014, 03:11 AM   #86
Bassplayinroach
Super Cool Since: Mar 2013
Locale: New Mexico
Postings: 265
Bassplayinroach is on a distinguished road
Is this swap thing still active?
I have:
(2)255
(2)260
I need:
(1)235
(1)240
(2)245
Look twice; save a life!
Bassplayinroach is offline   Reply With Quote
Old 09-28-2014, 10:59 AM   #87
Good Times
Good Times's Avatar
Locale: Too-son
Postings: 4,684
Good Times has a spectacular aura aboutGood Times has a spectacular aura aboutGood Times has a spectacular aura about
If you have a local BMW motorcycle dealer, you may be able to get shims from them. I think there's a shim bank here in Tucson, but it's so much easier to go to Ironhorse BMW and raid their collection.
I also have a BMW and have been a bit of a pest with the guy who mans the parts desk, so he knows me. Last time I did a shim run, he traded me 1 for 1 my old shims for the ones I needed. (I think the BMW dealer is the only one I've ever actually liked!)
Brian Lamberts
'94 Sportster XL1200
'04 KLR
'98 DR350SE (Beauty)
'01 Por-sha! Boxster
Tucson AZ
Good Times is offline   Reply With Quote
shim, swap, valve
