Oil Fill Excercise...a must read...lots of pics!!! - Page 5 - KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum!
Old 06-12-2010, 04:55 AM   #81
stinker
Locale: 892745.96 Smoots WNW of SpoonBooty
Postings: 629
stinker is on a distinguished road
Default Re: Oil Fill Excercise...a must read...lots of pics!!!
I had to buy another Gal of Rotella, I could not find the Mobile1 15w-50 anywhere locally.
When I was breaking in my 09 I only filled with 2.5qt.s thinking the xtra 4oz. needed for
2.5liters would not make that much difference, I have having to keep an extra qt. around
to make up my next change.
stinker is offline   Reply With Quote
Old 06-15-2010, 01:16 AM   #82
quick5pnt0
quick5pnt0's Avatar
Super Cool Since: Sep 2009
Locale: PA
Postings: 215
quick5pnt0 is on a distinguished road
Personally I think this is all backwards. The manufacturer put the sight glass in that particular position to mark the proper level of oil the engine should have. When they recommend 2.5l they are giving a general suggestion on the amount of oil that might be needed to fill the engine but the sight glass is what you should be going by. If you put 2.5l in the engine and it was below the sight glass would you just assume it's ok because you went by what the manual suggests? Of course not and you shouldn't be doing that on the other end of the spectrum either.
My point? Always go by the sight glass or dipstick, not the suggestions in the manual.
RCNewz.ccom
quick5pnt0 is offline   Reply With Quote
Old 06-17-2010, 11:36 AM   #83
Henry David
Super Cool Since: Jun 2010
Locale: Michigan
Henry David is on a distinguished road
Originally Posted by wymanwinn View Post
stay with Mobil 1, 15w-50...
Wyman,
Great pictures and really good information. Thank you!
I am new to this forum and a fairly new owner of the KLR 650.
I have used Mobil 1 Racing 4T 10w-40 oil in my other bikes.
I see that you obviously recommend the Mobil 1, 15w-50 oil.
When I take your recommendation (and I plan to), I will be
saving at least $2 - $4 per quart of oil. I will also get a wider
range in protection - 10w-40 vs 15w-50.
Is there any downside to using "plain old automotive" Mobil 1?
Not trying to be a funny, just trying to learn.
Thanks again for all the good info.
Henry
Henry David is offline   Reply With Quote
Old 06-17-2010, 12:34 PM   #84
Postings: 9,772
wymanwinn has a spectacular aura aboutwymanwinn has a spectacular aura about
if there is a downside, i have yet to see it in over 32,000 miles...original clutch too...
in the KLR685, i change the oil every 2500 miles and filter every 5k...and is uses ZERO oil...
BTW...i buy my Mobil 1, 15w-50 at Wally World for about $26/5qts...
2013 BMW R1200RT...Sassy
2015 BMW S1000R...Duke
2006 KLR685...Critter
1998 Honda VFR800+...Kitty
OR IT COULD COST $1000 or MORE!!! think about it
EagleMike Products (https://www.eaglemike.com)...
Old 06-17-2010, 02:37 PM   #85
Henry David
Locale: Michigan
Wyman,
Hmmm...32,000 miles? Approximately $5.00 a quart vs. $9.00 a quart for
4T Motorcycle Oil? Sounds like a winner to me!
Thanks for the information and advice.
Henry
Old 06-17-2010, 02:55 PM   #86
Watt-man
Powertrain Geek
Watt-man's Avatar
Super Cool Since: Jan 2005
Locale: Phoenix, AZ
Postings: 2,481
Watt-man has a spectacular aura aboutWatt-man has a spectacular aura about
I will back up Wyman's data with my data: if there is a downside, I have yet to see it in 54,000 miles... original clutch too...
Watt-man
www.watt-man.com
'04 KLR650, 156,000 Miles
With a Thermo-Bob 2, Eagle Doo and Torsion spring. Original piston, rings, entire top end...
Ride it like you own it...
Watt-man is offline   Reply With Quote
Old 07-11-2010, 09:02 PM   #87
thevanrat
thevanrat's Avatar
Locale: 10,000 Lakes
Postings: 1,587
thevanrat is on a distinguished road
Are the fancy EM oil caps for sale or shipping yet?
I dont think I saw them on the website?
´¯`·.¸¸.·´¯`·.¸ ><((((((º>
New owner of a 2008 Versys!
Previous: 2009 KLR 650 | 31,809 miles
thevanrat is offline   Reply With Quote
Old 07-11-2010, 09:09 PM   #88
Postings: 9,772
call or email Mike...contact info in my sig line...he has em...
Old 07-11-2010, 09:11 PM   #89
thevanrat
thevanrat's Avatar
Postings: 1,587
Thanks Man, I am on it...
Old 07-12-2010, 10:25 PM   #90
martin c
Super Cool Since: Jan 2010
Locale: Buenos Aires - Argentina
Postings: 69
martin c is on a distinguished road
Hi wymanwinn, I'm from Argentina.
Can you tell me how many cc. are between upper and lower level ??
Thanks !!
martin c is offline   Reply With Quote
Old 07-13-2010, 02:20 PM   #91
Postings: 9,772
Thanks !!
A LOT...keep the oil to the very top, if not slightly over, of the sight glass...
Old 07-13-2010, 11:12 PM   #92
dbrewerton
Locale: Calgary, AB
Postings: 613
dbrewerton is on a distinguished road
https://www.klr650.net/forums/showthread.php?t=77985
To use Wyman's own pictures, a full fill is 2.5L (as stated on the engine). With 2L added, the window is about 2/3 full and at 1.5L it doesn't show in the window. Therefore, if you're at the bottom of the window, you're something like 800-odd ML low or close to a US Quart low or about 1/3 of the engine's oil is missing. As was stated above, A LOT. Follow Wyman's recommendations, I sure am. Rotella T for now until I reach around 5000KM/3000 Mi then Mobil 1 15-50.
'09 KLR-650 Blue (Blue KLR Club #98)
'08 Honda CBF-1000A8
'08 Ninja 250 (daughters)
'09 Yamaha BW50 scooter (other daughters)
'08 Suzuki DRZ-125L (Sold)
'02 Yamaha TTR-125L (Big Bore 150)(Sold)
'83 Honda Shadow VT500C (Sold)(Wonderful bike)
'71 Honda CT90 (Sold)
dbrewerton is offline   Reply With Quote
Old 07-14-2010, 12:53 AM   #93
Watt-man
Powertrain Geek
Watt-man's Avatar
Locale: Phoenix, AZ
Postings: 2,481
I measured this once during a fill on my bike and found it to be very close to 500 mL.
Watt-man
www.watt-man.com
Old 07-19-2010, 07:03 PM   #94
MotoBoss
MotoBoss's Avatar
Locale: Gateway To Southern Indiana
Postings: 27
MotoBoss is on a distinguished road
Thanks for the heads up reminder. Went out and added 10 ounces to bring it up to the top of the glass. Still have a little bubble at top when upright but feel comfortable with having enough without worrying about breather blow back. Luuuuuuuuuuuuuuking Gooooood!!
I'm never lost, I just don't know where I'm at.
MotoBoss is offline   Reply With Quote
Old 07-27-2010, 04:33 PM   #95
kawioops
kawioops's Avatar
Super Cool Since: Mar 2006
Locale: To hell and gone from spoonbooty!
Postings: 5,715
kawioops has a spectacular aura aboutkawioops has a spectacular aura about
Except that your point is wrong, because Kawasaki got the oil window level wrong, which is the point of this whole excercise.
This wasn't arrived at willy-nilly, both wymanwinn and Elden Carl of Top Gun motorcycles have observed and tested this theory and it has proven out. In fact, the observation of BOTH is that the recommended 2.5L IS correct, and the window is wrong.
For those who use the window, Elden recommends that you shim the bike to 5 degrees off vertical on the kickstand and fill to the very top of the window, so that a small bubble is visible, if you don't want to or don't have a measure cup.
No assumptions here, this has been tested by several different people.
One Cool and Froody Dude who really knows where his towel is! You Sass?
kawioops is offline   Reply With Quote
Old 07-27-2010, 05:00 PM   #96
Canuck1969
Canuck1969's Avatar
Locale: Burlington Ontario
Postings: 596
Canuck1969 is on a distinguished road
Fully agree. The volume required by the engine is set out in the engine design. The position of the site glass is put in to match that volume. Someone goofed....and it happens....and the glass is lower than required....not by much...but enough. All I know is at my last oil change I put in the 2.5 litres (just used the hach marks on the 4litre jug) and I did not spit any oil out of the breather and I never had to add a drop of oil, even after many trips at highway speeds.....thats a first. When I drained it I measured the oil out and got back about 2.4 litres (again using my waste jug to measure....really need to get a measuring cup). Not bad concidering I was usually adding 400 to 600 mls between oil changes.
I am a believer........
2009 KLR650: Her name is KLaiR. Mount her every day ........She never complains
Motech Bars, LED Brake Light, Oxford Heated Grips, Centech Block, UNI Filter, KLX Needle, Barkbusters, ZG Screen, IMS Shifter, 16T, EM Fork Brace, Kaoko Throttle Lock, Sargent Seat, Alum. Skid Plate, Eagle Bar Risers, Denali Driving lights, 134 dB Auto Horn, EM DOO, Removable Pelican Cases with integrated locks, Progressive Suspension Front and Rear, Trailtech Striker, Procycle Thermo Bypass
Canuck1969 is offline   Reply With Quote
Old 08-06-2010, 01:34 PM   #97
Evilnut
Evilnut's Avatar
Locale: Lake Stevens, WA
Postings: 1,083
Evilnut is on a distinguished road
I have changed my oil at least a dozen times on my 08. Always drain it for about 30 minutes with a fully warmed up motor (Until the radiator fan kicks on). I have always changed the filter with the oil. Every time I have put 2.5L in as measured in a pitcher I have marked like Wyman does. Never had a problem with oil in the air-box/filter. Oil level is above the sight glass. Mine does burn oil, so as soon as it dips below the top mark on the sight glass, I add about 350 cc's as marked on the same pitcher, takes it at least to the top of the sight glass. Bike runs at the same temp is has since the day I bought it.
Evilnut (Tim)
2008 Red KLR650 (New 5/1/08) 685 Kit, Head Ported, Airbox Mod, Carb Jetted/Tuned (M-Tech!), V&H Exhaust, Happy Trails Protection kit, Mast Cyl Guard, SW Motech Rear Rack, IMS Extended Shifter, Madstad w/Adv Scrn, RAM X mount, 12V outlet, Grip Puppies, eBay rear side racks, BarkBuster Storm's, Dunlop D606's; ATGATT!
Evilnut is offline   Reply With Quote
Old 08-06-2010, 01:54 PM   #98
pwatkins
pwatkins's Avatar
Locale: Melbourne, Australia.
Postings: 320
pwatkins is on a distinguished road
the Hot run level is about 200ml more at 5,500 rpm, than the 2.5 recomended making the cold fill amount 2.7 litres this I'v tested on the Dyno. Simply the engine will suspend about 200 ml when running so the sight glas is comfort item not an exact qty.
Hi there all in KLR land
An 88, Blue Club member #106 & 09 #152
pwatkins is offline   Reply With Quote
Old 08-06-2010, 02:20 PM   #99
stinker
Postings: 629
I've been watching this thread off n on and now it is 7 pages & someone is saying I need to shim my KLR on the side stand to check the oil properly, when did that happen post #68??
IF my 09 is on it's sidestand and on my level garage floor what should the glass show?
In the past I've just been eyeballing 2.5L (2.6qt) out of my gal jug of Rotella.
Old 08-06-2010, 02:33 PM   #100
kzlr
kzlr's Avatar
Locale: El Dorado Hills, CA
Postings: 3,978
kzlr is on a distinguished road
Last picture of first post of this thread.
"empty looking, isn't it?"
Hope this helps,
K
Everybody Lies.
I was lying when I said that.
08 - "Joker"
"Error of Opinion may be tolerated where Reason is left free to combat it." - Thomas Jefferson
kzlr is offline   Reply With Quote
excercisea, fill, oil, pics, readlots
Correct oil grade? pmstirling KLR650 Second Generation 83 06-27-2014 10:37 AM
My soul ride..... lots of pics John37 General Photography 9 05-16-2009 02:55 PM
2006 klr problems:burning lots of oil! edfitzfish KLR650 Maintenance, Modifications & Technical 1 08-13-2008 08:50 PM
I'M NEW , is it normal for a 08 klr to use oil trsigmon Member Introductions 6 07-26-2008 01:31 PM
Drinking Oil gnostic203 KLR650 Second Generation 212 10-26-2007 12:16 PM
