LED headlight ? - KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum!
Go Back   KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum! > KLR650 Discussion Forums > KLR650 Second Generation
KLR650 Second Generation 2008-2017+ Related Topics
Old 02-04-2018, 12:42 AM   #1
nessy357
Super Cool Since: Feb 2018
Locale: Nanaimo BC Can.
Postings: 8
nessy357 is on a distinguished road
Default LED headlight ?
I have a Gerbing heated jacket liner and gloves, wondering if they would have to big a draw on the battery, so wondering if switched to a LED headight would fix the problem ?
nessy357 is offline   Reply With Quote
Old 02-04-2018, 08:25 AM   #2
spooky
spooky's Avatar
Super Cool Since: Jun 2012
Locale: New Hampshire ( Concord area )
Postings: 588
spooky is on a distinguished road
Default Re: LED headlight ?
Determine the amount of Amperage the clothing will draw first.
I have an older jacket, and gloves from Gerbing. I also have stock headlight.
No problems running both. If you have to idle for long time, just increase RPM's slightly. Also suggest installing a voltage indicator on the bike to keep an eye on the amount of charge while riding. ( A good idea anyway, Always know what your charging system is doing.)
Here's one I've used on many bikes / tractor, etc. https://www.amazon.com/Kuryakyn-4218.../dp/B000GU5WNO
1990 Honda NX250
2002 Honda GL1800
2011 Kawasaki KLR650
spooky is offline   Reply With Quote
Old 02-04-2018, 12:08 PM   #3
Candubrain
Super Cool Since: Oct 2017
Locale: Kincardine, ON, Canada
Postings: 11
Candubrain is on a distinguished road
I read somewhere the Gen 2's have 7 free amps available, (under ideal conditions).
I have an older Gerbing jacket and gloves, combined they draw 8 amps.
I do use the Gerbing controller so I know I'm not always drawing the full amperage, but I've decided to go a different route as I don't feel there is enough gain switching to LED lights to justify the cost. My 2014 HD has factory LED headlights and spots, they're crap in the rain as the white light glares back instead of cutting through like a warm casndecent bulb does.
Going instead with Oxford grips, and Hippo Hands. My hands are the biggest problem, and another sweater will make up for the Gerbing jacket.
Volt meter is a great idea, I'll be adding that as well.
Candubrain is offline   Reply With Quote
Old 02-05-2018, 06:41 PM   #4
bigjohnsd
Super Cool Since: Aug 2016
Locale: Spearfish, SD
Postings: 74
bigjohnsd is on a distinguished road
I ran IdaBaker's LED lights last year going to and from Inuvik. My Gerbing Jacket and Gloves ran fine with the Gerbing Digital Controller. My Voltmeter rarely read below 13.8 volts going down the road.
I've run the clothing with the stock H-7 bulbs as well, below 13.2 Volts at idle, but fine going down the road.
I had no trouble with the LED lights reflecting back through the rain, but...I wasn't riding at night either.
09 Blue - The "Blue Beast" BLUE#341
EM 685 and a whole lot of other stuff too!
Tusk panniers, Tusk 320 mm Front brake
A Veteran of the " Dempster Highway" and Dust to Dawson 25th Anniversary 2017
bigjohnsd is offline   Reply With Quote
Old 02-06-2018, 12:18 PM   #5
nessy357
Postings: 8
Thank you, great information !Never thought about adding a voltmeter, will do that for sure.
Thanks again.
Old 02-06-2018, 01:29 PM   #6
spooky
spooky's Avatar
Postings: 588
Thanks again.
Connect it where the power goes off, when you shut down. LED volt indicators draw a small amount of juice, but over time, it could draw down a battery, if you don't ride often.
1990 Honda NX250
2002 Honda GL1800
Old 02-07-2018, 03:13 PM   #7
nessy357
Postings: 8
Will do , thanks Spooky
Old 02-07-2018, 09:14 PM   #8
spooky
spooky's Avatar
Postings: 588
Thanks !
1990 Honda NX250
2002 Honda GL1800
Old 02-10-2018, 09:03 AM   #9
Voltar
Super Cool Since: Jun 2015
Locale: Near enuf to Austin
Postings: 209
Voltar is on a distinguished road
I run a Gerbing jacket liner (no gloves) and don't have any issues. At idle I will switch to low beam, but my voltmeter suggests that the Gen 2 KLR holds up fine. I bought my voltmeter from Amazon and got like five or so for under $10. I mounted it under the cowl with JST connectors and a tie wrap strap. If if gets wet or breaks I will just plug in one of my spares. That said, it's been fine for over 2.5 years.
My projects and stuff...
Voltar is offline   Reply With Quote
Old 02-13-2018, 02:03 AM   #10
nessy357
Postings: 8
That's perfect ! Thanks,I like how you've done that !
Cheers Bob
headlight, led
JNS LED Headlight DPelletier KLR650 First Generation 24 02-17-2018 01:35 PM
Superbright LED Headlight Bulb Double Denim KLR650 Maintenance, Modifications & Technical 7 01-29-2018 04:44 PM
Anyone done the Bikemaster LED Headlight upgrade? Epeescott KLR650 Maintenance, Modifications & Technical 0 03-18-2017 09:25 PM
LED Headlight. Gen 1, free sanibel Classifieds 4 12-16-2016 08:09 PM
Eastern Beaver + LED Headlight - Necessary? shadinsb KLR650 Maintenance, Modifications & Technical 1 08-22-2016 06:23 PM
