Brake system - Page 2 - KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum!
Go Back   KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum! > KLR650 Discussion Forums > KLR650 Maintenance, Modifications & Technical
KLR650 Maintenance, Modifications & Technical Wrenching and mods - KLR650 Technical discussion only!
Old 08-05-2017, 05:44 PM   #21
jcdied4me
Super Cool Since: Aug 2013
Locale: California
Postings: 238
jcdied4me is on a distinguished road
Default Re: Brake system
I appreciate all the help.
Update:
So, I purchased a caliper kit for both calipers. The SV kit had the wrong size cylinder seals. Apparently the ABS version is 25mm and the non ABS is 30mm. The k&l kit was the solution. Once I had both kits in hand I had both calipers rebuilt within two hours. I did a thorough cleaning using brake cleaner and a tooth brush. The SV caliper had a white gel like substance behind the cultivar that was not moving. The fluid in the caliper must have swelled due to moisture. once rebuilt and on the bike, I used an air compressor oil bleeding tool to repopulate the lines with the new dot4 fluid. I then bleed the brakes like usual to get out all the air. Both front and rear work like new.
Sent from my iPhone using Tapatalk
Jeff C: SoCal resident: 1992 KLR650
jcdied4me is offline   Reply With Quote
brake, system
