What did you do to your KLR today??? - Page 747 - KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum!
Go Back   KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum! > KLR650 Discussion Forums > KLR650 Second Generation
KLR650 Second Generation 2008-2017+ Related Topics
Old 09-24-2017, 03:00 PM   #14921
Campfire
Campfire's Avatar
Super Cool Since: Jun 2010
Locale: Napa, CA
Postings: 370
Campfire is on a distinguished road
Default Re: What did you do to your KLR today???
Amazing fall weather here in northern California. A little breezy, 74 degrees with a few light wispy clouds.
Perfect day for a ride! Up the coast? Over across the Delta?
Nah! I'll stay here and scrape some more gaskets and wait for the UPS truck tomorrow.
Confidence is the feeling you have before you fully understand the situation.
Jeff in Napa
2008 KLR, 688 kit,
1999 Toyota Land Cruiser
Campfire is offline   Reply With Quote
Old 09-25-2017, 12:49 AM   #14922
krmn59
krmn59's Avatar
Super Cool Since: Jan 2005
Locale: Somewhere in my toyhauler!!!!!!
Postings: 42
krmn59 is on a distinguished road
Originally Posted by rebar View Post
Not today but this week, I installed a set of adjustable kickstands on my 2009. Yes, you read correctly, a set. One for each side of the bike. I think that they will be really handy when working on both sides of my bike.
KLRCHRIS.COM sells them in a set ready to bolt into place. My bike is tall so I needed the length adjustment. Ride Safe James
[IMG][/IMG]
I have been wanting to do this for years, saw pictures of them years ago on a Kawasaki Stockman from Australia, thought it would be a much better setup than a center stand while off-road. Never knew that someone actually made them.
I do have a question on use, can you use both at the same time to lift the rear tire for chain maintainence?
Thanks for posting.
“Travel is fatal to prejudice, bigotry, and narrow-mindedness, and many of our people need it sorely on these accounts." Mark Twain
krmn59 is offline   Reply With Quote
Old 09-25-2017, 07:54 AM   #14923
rebar
Super Cool Since: Nov 2010
Locale: friendswood, texas
Postings: 103
rebar is on a distinguished road
Thanks for posting.
Good question! I don't think that would be convenient, but you could use one of the varieties of a " trail jack" on the left side for better access to the chain. A friend of mine was able to support the bike for shock repair/replacement by using rocks under both stands. Maybe he will chime in with details on how he did that. Ride safe James
rebar is offline   Reply With Quote
Old 09-25-2017, 11:12 AM   #14924
krmn59
krmn59's Avatar
Postings: 42
Rebar, thanks for answering my questions.
I always end up using my trunk box when I have needed to remove the rear tire on the road. I am hoping that the dual kickstand would act kind of like a center stand. I was thinking that if you extended the kickstands a little put down one of them then pushed the bike sideways toward the stand on the ground so the rear tire lifts and then put down the other kickstand that it might hold the bike up with rear tire off the ground. Kind of a build in trail-jack.
Old 09-25-2017, 02:27 PM   #14925
klr650gal
Super Cool Since: May 2017
Locale: Portland, OR
Postings: 115
klr650gal is on a distinguished road
I cleaned her up, installed my new sticker "Bigfoot doesn't believe in you either", and lubed the chain. Yes, I lube my chain more than most, but I figure it can't hurt... I had a couple of really nice rides over the weekend,so now I have to scrape the bug debris off to tell what color she is again. I had hoped the bugs were done for the year, but not quite yet...
klr650gal is offline   Reply With Quote
Old 09-25-2017, 06:25 PM   #14926
Maverick1701
Maverick1701's Avatar
Super Cool Since: May 2013
Locale: Lakeview, TX 79239
Postings: 400
Maverick1701 is on a distinguished road
I knocked out a few minor things I started yesterday.
track down a replacement license plate blub, find a replacement grade 8 bolt for my pannier rank (mine vibrated out somewhere), removed some LED rear turn signals/clearance light-things installed by the PO, fixed some wiring that was "fixed" by the dealer (they fixed some wiring done by the PO. after the "fix" my headlight didnt work).
It's not back on the road and ready to rock!!
Click image for larger version
ID:	65143  Click image for larger version
Chris
2003 KLR650
16t front sprocket, TwinHeadlightErnie driving lights/mounts, 2 $14 LED light bars, EM RL1 Raising Links, Motech Crash bars, Motech Center Stand, Nuvi260W, Dirttracks Racks, MCM Electronics Boxes, Vista Cruise Throttle Lock, "I heart my bike" bicycle bell.
Maverick1701 is offline   Reply With Quote
Old 09-26-2017, 11:21 AM   #14927
klr650gal
Postings: 115
Hey Maverick, what brand of hand protectors are those? The bike looks like it might be a bit hard to ride with the invisible seat and gas tank though ...
Old 09-26-2017, 11:36 AM   #14928
Maverick1701
Postings: 400
Those are acerbis brand bark busters with the plastic hand protector pieces removed (the plastic didn't survive very long & I found that the steel support still does a GREAT job at protecting my hands and bike controls).
Chris
2003 KLR650
Old 10-07-2017, 11:44 PM   #14929
Campfire
Campfire's Avatar
Locale: Napa, CA
Postings: 370
Finished up the 685 install on Tuesday, and the break-in rides. I've been cruising it around happy again and then someone else pulled in front of me on their cell phone. That little KLR horn just doesn't cut it.
I ordered this a while back and decided that today was the day. It's a Stebel Nautilus air horn.
Found some tubing, did some fitting, and then the welder came out, drilled some holes, and it all fit under the fairing.
Found an old fog light harness complete with a relay that's the same as the one that came with the horn. A little cutting, some connectors and it's in and working!
No one will expect to see a bike when I honk this thing. It sounds great!
Jeff in Napa
2008 KLR, 688 kit,
Old 10-09-2017, 03:54 PM   #14930
Small_life
Small_life's Avatar
Super Cool Since: Aug 2017
Locale: Texas
Postings: 31
Small_life is on a distinguished road
I actually also installed the Stebel Nautilus on Saturday. Then I took it to the inspection place so I could get it street legal. I think the inspector needed a new pair of pants when I hit it. The look on his face was priceless.
Right now I just have it zip tied on. Where did you get that bracket, or did you make it? I need to get one but am not a welder so looking at options.
Edit:i just realized your bike is Gen 2, and my understanding is that mounting brackets are not compatible between the two
Jason
1988 Kawasaki KLR 650, engine replaced with a 2000 model year.
Small_life is offline   Reply With Quote
Old 10-09-2017, 07:15 PM   #14931
spooky
spooky's Avatar
Super Cool Since: Jun 2012
Locale: New Hampshire ( Concord area )
Postings: 563
spooky is on a distinguished road
My state inspector had same reaction, when he said "now the horn?"
I put a Harbor Freight set on my KLR. 2 horns cost $10.00
Video... https://www.youtube.com/watch?v=wdt2lReXGIQ
Harbor Freight horn set.... https://www.harborfreight.com/2-piec...set-99911.html
1990 Honda NX250
2002 Honda GL1800
2011 Kawasaki KLR650
spooky is offline   Reply With Quote
Old 10-09-2017, 09:09 PM   #14932
Small_life
Small_life's Avatar
Locale: Texas
Postings: 31
that set was a steal and it sounds just as good as the stebel which is over twice the price
Jason
Old 10-10-2017, 06:04 AM   #14933
spooky
spooky's Avatar
Postings: 563
I had originally put a set on my Honda NX250 many years ago. I still have them on there, and they still perform like new. Being a small bike, I need all the sound I can get.
1990 Honda NX250
2002 Honda GL1800
Old 10-10-2017, 11:04 AM   #14934
klr650gal
Postings: 115
Scrub a dub dub, KLR in the tub! Just kidding, but I did clean the bike off, as I had encountered a heavy dose of gnats. I guess I shouldn't ride by Gnat Creek and environs... The windscreen was really bad, as were all forward facing surfaces. Kind of like a stucco bath tub...
Old 10-10-2017, 06:16 PM   #14935
Campfire
Campfire's Avatar
Locale: Napa, CA
Postings: 370
Made the bracket, and I always enjoy having a welder in the garage.
Got to use it for the first time the other day. They had no idea where that noise from coming from.
Sent from my iPhone using Tapatalk
Jeff in Napa
2008 KLR, 688 kit,
Old 10-11-2017, 04:04 AM   #14936
sasho
Locale: Missoula, MT
Postings: 372
sasho is on a distinguished road
This was during the summer, anniversary during the Best of Montana ride:
Past rides: PNW KLR Rally 2010 & 2012, Happy Trails 25th anniversary KLR Rally 2012, MT to Alaska 2011, Magruder Corridor 2012, Eastern Montana 2012, Eastern Europe 2012, Bulgaria 2013, MT/ID/NV/CA/OR 2013, Beartooth Hwy 2014. Best of Montana 1000 (2013, 2014, and 2015), 9 Balkan Countries 2014, ADV Wallowa Jamboree 2015, Mexico Baja 2015
Wish list:around the Black Sea, Siberia, Utah, Africa, Australia and NZ
sasho is online now   Reply With Quote
Old 10-11-2017, 10:24 AM   #14937
klr650gal
Postings: 115
Hey you two, get a room! Congratulations on making the big 60,000 mark.
klr, today
