Highway question - KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum!
Go Back   KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum! > Ride Reports, Photo & Video > Ride Reports & Trip Planning
Ride Reports & Trip Planning Are you ready for some great riding and adventure stories!?
Old 08-07-2017, 09:12 PM   #1
ramitupurs84
Super Cool Since: Jul 2017
Locale: Bay City, MI
Postings: 25
ramitupurs84 is on a distinguished road
Default Highway question
I'm new this motorcycles and this is my first KLR. So this maybe a silly question: I see all these posts and YouTube channels globe trotting. How often is people rolling at highway speeds all bagged down with gear? Or are you mapping out roads with a lower speed limit?
ramitupurs84 is offline   Reply With Quote
Old 08-07-2017, 09:34 PM   #2
Robert Z
Robert Z's Avatar
Super Cool Since: Jan 2012
Locale: Oregon Coast
Postings: 500
Robert Z is a name known to allRobert Z is a name known to allRobert Z is a name known to allRobert Z is a name known to allRobert Z is a name known to allRobert Z is a name known to all
Default Re: Highway question
Both and yes.
Very individual... depending on your gear, your setup, and yourself.
Also, define "freeway speeds" that can be anywhere from 55mph to 80mph here in the states.
First you need to figure out what you want to do.
Then figure out what you can do.
Lastly, make a compromise between the two.
Just remember. The speed limit is the MAXIMUM speed allowed by law. Doing 55 in a 65 zone is not going to get you pulled over... and some freeways limit big trucks and those hauling trailers to 55, even if the speed limit is 70.
Some freeway, some two lane, a little bit of everything makes for an adventure.
Blue KLR club member #243 Post a pic of your bike here, then pm me for membership. https://www.klr650.net/forums/showthr...light=blue+klr
I am a leaf on the wind, watch how I soar.
Robert Z is offline   Reply With Quote
Old 08-08-2017, 12:53 AM   #3
packnrat
Super Cool Since: Apr 2015
Locale: in them hills.
Postings: 308
packnrat is on a distinguished road
Smile Re: Highway question
for some the freeways are it.
for others dirt trails are it.
you have to answer this yourself. try different ways. but just remember the point of it all is not the how, but the end result.
do not worry the trip, just enjoy the ride.
i have a couple bikes, both do it worlds apart. and both are fun. get me away.
and i live.
packnrat is offline   Reply With Quote
Old 08-08-2017, 09:02 AM   #4
ramitupurs84
Postings: 25
Sorry I'm talking about 70 mph for highway speeds. I've had mine up to 65mph. I've read that they wobble pretty bad at highway speeds. I also heard the 2nd hens burn oil at maintained speeds. I'm 300 lbs and a lot of bikes look like they have more than myself alone running around the world on a KLR
Old 08-08-2017, 10:25 AM   #5
ptxyz
ptxyz's Avatar
Super Cool Since: Feb 2011
Locale: san jose, california
Postings: 1,406
ptxyz is on a distinguished road
i've had mine at 80-90 for extended periods with a passenger, saddlebags and tail box. yes, the bike is capable of such abuse!
before doing so, i checked and tightened the steering head bearings, adjusted suspension sag (with only me on the bike) and made sure the tires were around 32 psi each.
there are a few things that can contribute to a high speed wobble. if you're experiencing this, research more here and rule them out on your bike.
yes, these motors can burn oil above 5k rpm, check your oil at least at every fuel stop if you're asking it to do so.
not the end of the world to wobble, even at high speeds. gently roll off the throttle, don't try to fight with the grips and lean forward slightly, the bike will stabilize.
2000 klr 650
2001 cbr1100xx
1998 e430
1971 914 1.7
paul
ptxyz is offline   Reply With Quote
Old 08-08-2017, 10:55 AM   #6
Robert Z
Robert Z's Avatar
Postings: 500
Originally Posted by ramitupurs84 View Post
Sorry I'm talking about 70 mph for highway speeds. This is addressed through several things, mainly gearing and overbore.I've had mine up to 65mph. I've read that they wobble pretty bad at highway speeds. Does your wobble?I also heard the 2nd hens burn oil at maintained speeds.rpms, not speeds I'm 300 lbs and a lot of bikes look like they have more than myself alone running around the world on a KLR
Everything effects everything. Here we go.
1. Tires. If you're going to slab, have street tires, otherwise, SLOW DOWN.
2. RPM's. The magic number seems to be 5k. Change your gearing to increase your top speed while staying under that number. Change sprockets as needed. Stock is 15/43. You can change to a 14 at the trailhead, and to a 16 (or 17) to slab with. I like 16/42 for in town commuting.
3. Overbore. The only way to get real power increase, and not much of that at all, is to go bigger. A 685 is a good kit (Eagle Mike) that will provide noticeable power while reducing vibrations.
4. Load correctly. Weight needs to be down low, and keep the center of gravity towards the middle. Don't put a crap ton of weight on the rear deck, you will lift the front, and there goes your stability. Take half the crap...
5. Lose weight. I'm guilty of this. It is very simple. If you want your bike lighter, lose weight. I'm 6' and crowning 260. In order for my bike to perform better, I should lose at least 60lbs. It's on my to-do list.
6. Suspension. Stock sucks. Especially at your weight. Adding luggage will make it worse. Couple of good options out there. The stock will get you by, but barely.
Now here's some all around wisdom.
Keep your tires inflated properly.
Check your oil every time you throw a leg over. Yes, I do it every time. Some people say at each fill up, but I've had a situation where I went full throttle, overloaded, with a 17t front, and ate about a third of the oil before I stopped for gas.
Seriously... go light, check your oil obsessively, throw a 16t on the front, and you should be fine for sustained 70mph travel.
Been there, done that, 70k miles worth. I used my 2011 for commuting, battling the cagers in the afternoons at speeds of 70-80 mph, five days a week.
Old 08-08-2017, 09:31 PM   #7
PittsDriver
PittsDriver's Avatar
Super Cool Since: Sep 2014
Locale: Annapolis MD
Postings: 730
PittsDriver is on a distinguished road
My bike, loaded in that photo, was ridden for many hundreds of miles at a time at 80 mph. Dunlop D606 rear, Pirelli MT-21 front, OEM suspension. I weigh 200 lbs plus my riding gear.
And yep, I rode it 700 miles once at those speeds with a 14/43 final drive and over that distance it burned about a quart of oil.
It will wobble a bit over 85 but it'll run over 90 even with my current 14/47 final drive.
Current stable:
'14 KLR 650 NE (for the TAT)
'16 R1200GS (for epic adventuring)
'16 KTM 1290 R Super Duke (for my inner hooligan)
PittsDriver is offline   Reply With Quote
Old 08-08-2017, 11:18 PM   #8
sycamoredave
Super Cool Since: Nov 2010
Locale: Mount Vernon, OH
Postings: 156
sycamoredave is on a distinguished road
KLR is a compromise. It will go 80 mph and will do dirt, but you have to be sensitive to what the bike is doing and manage your riding carefully. To handle both ends of the spectrum, I have found that having a good set of dual sport tires at appropriate pressure (32-35 psi for street, 20 psi for gravel and dirt), using a fork brace, and swapping out the stock fender for a motard (KTM) fender, all seem to help. Avoiding overloading is important. The motor will consume oil at higher rpms. Be prepared to adjust speed if wind, road and other conditions make things a bit sketchy. KLRs have been ridden successfully from coast to coast in all kinds of crazy conditions, so handling your MI road conditions should not be a big deal. Ride safe and have fun!
Best wishes...
Dave
sycamoredave is offline   Reply With Quote
Old 08-08-2017, 11:53 PM   #9
roadapple
roadapple's Avatar
Super Cool Since: Nov 2008
Locale: Chicago, IL
Postings: 785
roadapple is on a distinguished road
There are better bikes out there that are more complicated, more expensive, faster, more power, bigger. There are smaller bikes too. The KLR 650 is adequate for some but some of us want more for different reasons. If that reason is important enough maybe you have the wrong bike.
There are vast numbers of KLR 650's, parts and technical support, and yes even some good dealers here and there. There is still world-wide travel appeal.
There are known proven modifications that have track records over time and miles.
The two areas most improved thru mods are suspension and engine performance.
It remains a tall, five speed, 50mpg thumper with limited horsepower. It's design is dated and not going forward. Each new year people wait with baited breath for a new color. Some of us run 85-90 with an overloaded KLR and think it's OK.
Some of us test drive a Versys 300X, a CB500X, a KTM 1090R, a Ducati Multistrada and see the beginning of the end of the KLR.
roadapple is offline   Reply With Quote
Old 08-11-2017, 11:15 PM   #10
verboten1
verboten1's Avatar
Locale: Monroe, MI
Postings: 1,258
verboten1 is on a distinguished road
I was 300 pounds, fully loaded, riding the KLR to bay city and farther. It's no big deal, keep an eye on your oil.
'82 XV920- Tracker?
'00 KLR685
'04 DRZ400 Dirtybike
'12 Super Tenere XT1200
'13 Versys 650 For the wife
James Bay Madness!!!
verboten1 is offline   Reply With Quote
Old 08-13-2017, 08:55 AM   #11
ramitupurs84
Postings: 25
Awesome to know a local on here.
Old 08-13-2017, 10:45 PM   #12
DanBarwick
DanBarwick's Avatar
Super Cool Since: Jun 2014
Locale: Independence, Kansas
Postings: 1,010
DanBarwick is on a distinguished road
Fork brace and smaller front fender really helped when I started taking it up around 80.
Fast, good, cheap - choose two.
2009 KLR, EM 685 kit, full Cogent treatment, goes anywhere
2005 Yamaha TW200, actually this is the one that REALLY goes anywhere
1999 BMW r1100rt, a true continent crusher
DanBarwick is offline   Reply With Quote
highway, question
Ignition Coil Question CanyonDays KLR650 First Generation 16 09-13-2016 12:56 AM
2006 KLR650 carb question Howurd KLR650 Maintenance, Modifications & Technical 15 04-24-2016 03:48 AM
Best Gear Rato for highway use??? twhiddon13 KLR650 First Generation 7 10-30-2015 07:36 PM
Balancer Question Doc Joe KLR650 Maintenance, Modifications & Technical 1 09-03-2015 07:45 AM
highway or back roads? hobbyhasher KLR650 Second Generation 30 08-27-2015 11:50 AM
