Bike Just Starts Cutting Out (Strange) - KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum!
Go Back   KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum! > KLR650 Discussion Forums > KLR650 Maintenance, Modifications & Technical
KLR650 Maintenance, Modifications & Technical Wrenching and mods - KLR650 Technical discussion only!
Old 12-05-2017, 08:19 AM   #1
Jeremy_283
Jeremy_283's Avatar
Super Cool Since: May 2009
Locale: Central U.S.
Postings: 312
Jeremy_283 is on a distinguished road
Default Bike Just Starts Cutting Out (Strange)
Seems to only occur in HOT or COLD weather while either on 20+ minute interstate runs or after being on the trails moving slow for a while.
The bike will be going good (like yesterday) then all of a sudden like a switch was flipped it will cut out. It is difficult to get above 35mph and while it cuts out at lower RPMs at 4,000rpm and above the cutting out is more pronounced (at any speed, at any throttle position, at any throttle load). If at a lower RPM and I turn the throttle fully it will cut out too. I can ride around town for 30 minutes and it'll never occur. If I let the bike sit overnight it's good for riding the next morning but if I let it sit for an hour it's not any better an hour later.
Air filter is clean, valves in spec. Fresh gas. No recent changes to the bike.
Thoughts?
Jeremy_283 is offline   Reply With Quote
Old 12-05-2017, 09:33 AM   #2
azklrian
Super Cool Since: Dec 2012
Locale: AZ/AB
Postings: 461
azklrian is on a distinguished road
Default Re: Bike Just Starts Cutting Out (Strange)
I would bypass the clutch and kick stand safety switches and see if that helped.
azklrian is online now   Reply With Quote
Old 12-05-2017, 11:07 AM   #3
DPelletier
DPelletier's Avatar
Super Cool Since: Aug 2010
Locale: Kelowna B.C.
Postings: 6,482
DPelletier will become famous soon enoughDPelletier will become famous soon enough
yep, sidestand and clutch safety switches first, then check the gas tank vent (run with the cap open to see if that fixes the problem), next up; vacuum petcock diaphragm failure. ....you don't have an aftermarket inline filter do you?
Dave
twins; 2000 & 2001 KLR's: Cogent suspension, 320mm rotor+SV calipers, IMS tanks+ tankvest, Knight designs pegs, Anti-gravity batteries, Renthal bars, MT21 and D606 tires, FMF Q4 and LeoVince X3, ...and most everything that Eaglemike makes! :-)
DPelletier is offline   Reply With Quote
Old 12-07-2017, 04:48 PM   #4
Jeremy_283
Jeremy_283's Avatar
Postings: 312
Dave
No in line filter. Kickstand switch made no difference nor does the gas cap. I could ride around town all day but it 5,000 rpm highway runs for 20+ minutes or slow trails is where the issues arise.
Old 12-07-2017, 05:16 PM   #5
DPelletier
DPelletier's Avatar
Postings: 6,482
there go the easy ones! ...maybe heat related....is the gauge showing hot when it does it? does your fan function and come on?
Dave
Old 12-07-2017, 05:19 PM   #6
DPelletier
DPelletier's Avatar
Postings: 6,482
the combination of when it occurs is strange; fuel delivery issues that would affect a bike after a sustained high speed run wouldn't manifest in low speed trails and likewise, a wiring harness rub through issue that could easily be triggered on low speed trails shouldn't happen going straight on the highway. Nonetheless, check the carb inlet screens in the tank for debris and it can't hurt to remove the tank and check the harness.
Dave
Old 12-07-2017, 07:01 PM   #7
jeffsaline
Locale: Rapid City, South Dakota
Postings: 9,363
jeffsaline is a jewel in the roughjeffsaline is a jewel in the roughjeffsaline is a jewel in the roughjeffsaline is a jewel in the rough
What year KLR650? Gen I and Gen II have some important differences.
What does the tachometer do when it is cutting out? Does the needle drop to zero like you turned off the key or does it follow engine rpm/road speed decrease?
Best,
Jeff
Jeff Saline
Do Not Steal, Do Not Lie, Do Not Be Lazy
"Just because something isn't true, no reason you can't believe it." Hub McCann in Secondhand Lions
"If you don't have a time table you can't be late. When you don't have a destination you can't get lost." Colin Stafford-Johnson, Ireland's Wild Coast
jeffsaline is offline   Reply With Quote
Old 12-07-2017, 07:15 PM   #8
K33
K33's Avatar
Super Cool Since: Jun 2016
Locale: Bahstahn
Postings: 190
K33 is on a distinguished road
The only thing those two situations seem to have in common is higher trapped heat, no? Can the carb overheat or something? The float should be cooled by the fuel, and not expand to float higher than normal, so I have no idea.
Steve K. -K33
Black '09, Gen2
Ride that Pig like it's BACON!
K33 is offline   Reply With Quote
Old 12-07-2017, 11:37 PM   #9
C5dad
C5dad's Avatar
Super Cool Since: Aug 2015
Postings: 276
C5dad is on a distinguished road
My sons bike had the same issue and it was pinholes in the diaphragm. He also had bits of rubber in the bowl from the petcock gasket as well.
The pinholes were hard to find BTW
I'm an engineer Jim, not a comedian!
Corbin Seat w upgraded seat pad, EM Fork Brace w/ Acerbis fender, Cogent Moab and front springs, USB and 12 v accessory outlet; Cee Bailey windsheld; MC Mod; deCalifornicated; upcoming 685 kit.
C5dad is offline   Reply With Quote
Old 12-08-2017, 11:57 AM   #10
Jeremy_283
Jeremy_283's Avatar
Postings: 312
The carb diaphram? It sure is an odd issue. I've never had carb issues before.
Old 12-08-2017, 12:15 PM   #11
K33
K33's Avatar
Locale: Bahstahn
Postings: 190
J. I think that is the petcock (vacuum) diaphragm
Steve K. -K33
Black '09, Gen2
bike, cutting, starts, strange
2002 USMC KLR 650 M1030b1 Patina Bike $3250 (Paid) QC123
KLR650 Motorcycles for sale or trade
1 11-28-2017 09:54 PM
Bike puking coolant after 685 install? clogan KLR650 Maintenance, Modifications & Technical 47 05-21-2016 09:05 AM
Upgrading the spring...sometimes you just have to laugh! clogan KLR650 Maintenance, Modifications & Technical 19 10-09-2015 02:12 PM
My bike still works!!! stiggles KLR650 Maintenance, Modifications & Technical 11 02-08-2015 12:25 PM
Bike keeps dying renimus KLR650 Second Generation 3 01-30-2015 04:06 PM
