LED Turn Signals - KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum!
Go Back   KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum! > Other Kawasaki Motorcycles > KLR250 and Super Sherpa Main Discussion
Old 07-02-2012, 09:00 PM   #1
KLRiderKTMracer104
Super Cool Since: Aug 2009
Locale: Ashland, Ohio
Postings: 34
KLRiderKTMracer104 is on a distinguished road
Default LED Turn Signals
Do you have to do anything special to install LED turn signals. My bike was tipped over a long time ago and broke the rear turn signal. Well you can get 4 LED ones on ebay for cheaper than the stock one. I actually prefer the LED ones look wise but wasn't sure if they would work or if there was something easy I could do to make them work.
Thanks guys I have been asking lots of questions lately.
KLRiderKTMracer104 is offline   Reply With Quote
Old 07-03-2012, 03:41 PM   #2
hodgie
Super Cool Since: Jun 2012
Locale: Southern VT
Postings: 13
hodgie is on a distinguished road
Default Re: LED Turn Signals
im actaully in the process of doing this myself. ive found, just as i expected, that there isnt enough draw to make the flasher flash. im trying to find out if i should solder in a resistor, or look for a new flasher. ill let you know if i find anything out before someone else who knows more chimes in.
hodgie is offline   Reply With Quote
Old 07-03-2012, 04:37 PM   #3
Baggey22
Baggey22's Avatar
Super Cool Since: Jan 2011
Locale: Westford, VT
Postings: 56
Baggey22 is on a distinguished road
I did this mod on my KLR a while ago. I changed out all the lamps (except the headlight) with LEDs. I bought everything from www.superbrightleds.com
The easiest solution is to go there and search "LF1-S-FLAT: Universal Motorcycle Flasher" Then install that in place of the stock location. It'll work with any type of lamp/bulb.
2006 KLX 250S - woods
1995 Kawasaki ZX6r - track
2008 Kawasaki ZZR600 - street
1987 KLR 250 parts bike. PM me with anything you might need!!
Baggey22 is offline   Reply With Quote
Old 07-03-2012, 05:35 PM   #4
AirJunky
AirJunky's Avatar
Super Cool Since: Oct 2011
Locale: Liberty Lake, WA
Postings: 599
AirJunky is on a distinguished road
So are you supposed to use an LF1 on each light? Is it installed inside the light housing?
Bill
- 2005 KLR 650
SW Motech crash bars, JNS skidplate, Moose hand guards, Shinko 705s, Deka AGM battery, Corbin flat seat, Duratool rear case, E.M. doohickey & subframe bolt upgrades....and still going.
AirJunky is offline   Reply With Quote
Old 07-04-2012, 02:29 AM   #5
kidflyr
kidflyr's Avatar
Locale: Ukiah, California
Postings: 419
kidflyr is on a distinguished road
Just one is required and it will be installed in place of the oem unit. It replaces the module which regulates the flashing of the oem incandescent lights. The LF1... module is able to operate normally across a broader range of voltage and amperages than the oem unit is capable of operating with a "normal" flash rate. With LED turn signals, the voltage isn't significantly different, if different at all, but much less amperage is required to operate the LED'S compared to the incandescent bulbs, resulting in the apparent malfunction when using the stock flasher module with LED turn signals.
The flasher relay is located beneath the fuel tank of your KLR 250 along the top tube of the frame among several other electronic modules such as the CDI module and several electrical connectors. The parts fiche on sites like bike bandit offer a better diagram than my copy of the service manual has to offer, or you can take off the tank and hit the turn signal switch and listen/feel got which of the small plastic plug like modules is the turn signal relay. It should click each cycle and a finger resting on the module will detect the click too.
Nick was here
Support this awesome resource! Go Premium!
1993 KLR250 * Titanium tibia * Kenda K761 tires * Airbox de-snorkled & opened up * PCV valve * UNI bulk foam filter * Modified exhaust port * 38pilot/135main * Capacitors in parallel with battery * LEDs all around * Jeffsaline's headlight relay * 16 tooth countershaft sprocket/40 tooth rear * WOLO "Bad Boy" horn
kidflyr is offline   Reply With Quote
Old 01-07-2013, 11:49 AM   #6
Thunder Strike
Thunder Strike's Avatar
Super Cool Since: Oct 2012
Locale: moon base
Postings: 51
Thunder Strike is on a distinguished road
I did some major off roading this weekend, and smashed the rear turn signal.
Now ordering the LF1-S-FLAT and some led rear signals.
I will reply when working.
Thanks,
JB
Thunder Strike is offline   Reply With Quote
Old 05-01-2013, 10:04 PM   #7
bigredcherokee
bigredcherokee's Avatar
Super Cool Since: May 2011
Locale: Shreveport,LA
Postings: 41
bigredcherokee is on a distinguished road
How did this LF1-S-Flat work out? I just replaced all four old turn signals with LED and purcased a LED flash off ebay. Now all I get is all the lights on at once. I see the LF1-S-Flat is the soltuions I believe to my problem but what do you do about the turn indicator bulb?
04 KLR
https://expedition-awareness.org
bigredcherokee is offline   Reply With Quote
Old 05-01-2013, 10:08 PM   #8
verboten1
verboten1's Avatar
Locale: Monroe, MI
Postings: 1,258
verboten1 is on a distinguished road
I've run these for years.
https://www.electrosport.com/led-turn...advantage.html
They do not break, and they are very nice, vs the crap eBay LED signals I tried before
'82 XV920- Tracker?
'00 KLR685
'04 DRZ400 Dirtybike
'12 Super Tenere XT1200
'13 Versys 650 For the wife
James Bay Madness!!!
verboten1 is offline   Reply With Quote
Old 05-02-2013, 02:10 PM   #9
juddspaintballs
juddspaintballs's Avatar
Super Cool Since: Mar 2013
Locale: Berkeley Springs, WV
Postings: 618
juddspaintballs is on a distinguished road
I've been seriously considering a LED headlight recently. $200 for a 7" round dual beam headlight from trucklite on ebay. It's been done before as I've discovered from a few Google searches and I really like the look. I have the 24v version LED headlights on my M35a2 and I absolutely love them for lighting up the road. DOT approved too.
juddspaintballs is offline   Reply With Quote
Old 05-04-2013, 03:33 AM   #10
simpke
Locale: Kansas City, MO
Postings: 7
simpke is on a distinguished road
Was the LF1-S the answer? Getting ready to order 4 led signals. Love to hear from any of you guys that have had success with this.
simpke is offline   Reply With Quote
Old 11-03-2016, 02:24 AM   #11
IdaRida
IdaRida's Avatar
Super Cool Since: Oct 2016
Locale: Salmon, Id
Postings: 23
IdaRida is on a distinguished road
Can anyone tell me exactly where the turn signal rely is located on a 15? Thanks
IdaRida is offline   Reply With Quote
Old 09-22-2017, 09:39 PM   #12
Jakwriter
Because why not?
Jakwriter's Avatar
Super Cool Since: Apr 2010
Locale: Corvallis OR
Postings: 110
Jakwriter is on a distinguished road
I'm attempting the LED turn signal mod. Picked up four BAU15S LED stacks and the LF-S-FLAT relay. The OEM relay is located under the nose on 2nd Gens, towards the left side under the dash. Swapped out bulbs and the relay and . . . All four signals blink regardless of which direction I push the turn switch. Gave myself a headache trying to follow a wiring diagram, can't figure out how this is even happening.
I'm happier cracking the case, electrical has too many gremlins. Any ideas? Anyone?
At least it's a 685 now. Might be too fast for LED lights . . .
Jakwriter is offline   Reply With Quote
Old 09-23-2017, 04:36 PM   #13
Arizona_Elwood
Arizona_Elwood's Avatar
Super Cool Since: Jul 2014
Locale: Phoenix, Arizona
Postings: 660
Arizona_Elwood is a jewel in the roughArizona_Elwood is a jewel in the roughArizona_Elwood is a jewel in the rough
I swapped out my rear turn signals with LED but left the front stock incandescent. Found out that the remaining front signals provided enough resistance where I didn't need to swap out the flasher/relay..
Still saving up for the $.22 Mod.
Arizona_Elwood is offline   Reply With Quote
Old 09-23-2017, 07:12 PM   #14
Jakwriter
Because why not?
Jakwriter's Avatar
Postings: 110
Through some experimenting I ended up doing the same thing. But since the nose was off I swapped the relay. LED in front, incandescent in the back and all functions normally. Still can't figure out why going all LED makes the turn signal into hazard lights.
Old 10-13-2017, 06:57 AM   #15
Tweed tractor
Super Cool Since: Sep 2017
Locale: Tweed valley nsw
Postings: 2
Tweed tractor is on a distinguished road
Am doing the mod at the moment.
It's the dual role of the indicator lamp on the dash. It actually was designed to indicate faulty bulbs as well and joins the two sides electrically. Remove the bulb and no more hazard lights. Still looking at a work around that will need a diode I expect
Tweed tractor is offline   Reply With Quote
Old 10-13-2017, 05:11 PM   #16
Jakwriter
Because why not?
Jakwriter's Avatar
Postings: 110
I'm no guru, but I think a properly oriented diode on each of the dash indicator wires will allow it to function and prevent the 4-way action. I haven't bothered yet, but something like that might work. I can see my front signals from the saddle so I'm just rollin' without the dash indicator bulb.
Old 10-14-2017, 04:56 PM   #17
Tweed tractor
Postings: 2
Got it all working with a couple of 70 cent diodes from jaycar the local electronics store. You need something rated about half an amp and 20v.
Cut both leads to the turn signal repeater bulb
Attach a diode to each of the leads going back to bike that you just cut
The diode should have the bar marking away from the wire
Twist the two diode tails together (marking end) and connect to one lead of the bulb and connect the other lead of the bulb to a good ground
Replace the stock flasher unit with an LED compatible one of ebay
Old 01-06-2018, 08:26 PM   #18
Jakwriter
Because why not?
Jakwriter's Avatar
Postings: 110
Posted this on another thread too. But I threw in one of these in the turn signal indicator slot on the dash and didn't need any diodes. Not sure why though.
Works like a charm. Lags a bit behind the actual turn signal, but I don't see that as a problem. Same LED for the neutral, and a blue one for a high beam indicator that doesn't blind. At least I think so. Haven't actually driven with the highs on yet. However, the above LED are dimmer than the ones I used for dash lighting.
And yeah, green.
Looking forward to driving home after class, in the dark.
'08 685, doo, mod, mod, farkle, farkle, covered in truck bed liner and sutures.
No one rides a motorcycle to be safe. Then again, danger has a way of clarifying things.
"neither trucks nor attack trees will stay this rider from her appointed trails .... " - LaurieD
led, signals, turn
