Product list.... - KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - Original KLR650 Forum!
Go Back   KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - Original KLR650 Forum! > Premium Advertisers > Eagle Mfg & Eng
Hello, welcome back.
Eagle Mfg & Eng Click the banner to purchase! QUALITY. MADE IN USA! Forum operated by Eaglemike
Closed Thread
Old 11-06-2007, 10:36 AM   #1
Postings: 9,358
Eaglemike has much to be proud ofEaglemike has much to be proud ofEaglemike has much to be proud ofEaglemike has much to be proud ofEaglemike has much to be proud ofEaglemike has much to be proud ofEaglemike has much to be proud ofEaglemike has much to be proud of
Default Product list....
Balancer lever and spring(s) kit (aka doo' kit) 39.95 lever fits all years
Torsion spring for balancer lever 13.95 (includes required drill bit)
Rotor puller 12.95
Rotor holder wrench 24.95
Choke and mirror relocation bracket for 2007 and earlier 16.95 (includes 2 stainless allen screws)
Machined rear brake pedal and master cylinder mount with teflon sealed bushing 42.95
Handle bar risers .7 inch and 1.5 inch 29.95
Subframe bolt kits:
-drill though with bits 24.00
-drill through without bits 19.00
-bolt upgrade only kit 5.00
Raising and lowering links for 1987 through 2008, and for 2008 models (hard anodized, guaranteed as strong as or stronger than stock parts, lifetime exchange) $50 to 69.95
Prevailing torque nut for countershaft sprocket for 1996 through 2008 9.95
Shim kit for 1987 through 1995 countershaft, sometimes needed on later bikes 9.95
"Carrier Deck" luggage rack 79.95 back in production 7-08
Carb screw kits $5
Front master cylinder screw kit $2
Shark Fin rear disk protector $70.95
Fork Brace $109 (price going up 11-1-2008)
These prices do not include shipping!
I also stock the left side and right side engine gaskets. I keep on hand spare woodruff keys for the crankshaft to rotor assembly, spare thrust washers for the crankshaft to starter gear assembly, etc. If you run into an issue when working on your bike and need help, I'll try, even on the weekend. My cell number is in the instruction sheet with the lever and spring kit (all the others, too.)
Eric www.aviciouscycle.ca also carries almost everything. You can buy direct by sending me a check or using paypal. Credit cards are ok through paypal.
I'll update this as needed.
all the best,
https://eaglemike.com/ for parts.
Don't try to be a great man, just be a man, and let history make it's own decision
Eaglemike is offline
Closed Thread
list, product
Long (long) list of upgrades I've done SgtMarty KLR650 First Generation 15 02-09-2012 01:46 AM
Doo Tools Borrowing list MapBoy New England 23 02-23-2009 02:22 PM
Is there a product such as "Easy clutch" for the KLR Pierre KLR650 Maintenance, Modifications & Technical 15 12-03-2007 11:08 PM
2008 KLR650 Wish List Dakar dreamer KLR650 Second Generation 34 08-03-2007 07:33 PM
How do I list a bike for sale? Flyingpackman Off-Topic Discussion 3 11-06-2006 11:10 AM
