Improved Fuel Screw Extension - KLR650.NET Forums - Your Kawasaki KLR650 Forums Resource! - The Original KLR650 Forum!
Old 08-13-2009, 02:23 PM   #1
einfahrt
einfahrt's Avatar
Super Cool Since: Aug 2007
Locale: Oklahoma
Postings: 600
einfahrt is on a distinguished road
Default Improved Fuel Screw Extension
Let's try this again, this time message composed off line so no chance of getting booted out. I also used Preview Post instead of Submit then Edit, as suggest by Glenn, to also reduce getting booted out.
Enjoy!
Zerebrel (Engineering Services)
Chris Johnson (Einfahrt)
Low Budget Fuel Screw Extension
BACKGROUND
The Keihin CVK carburetor is a great carburetor design. As a result of emissions mandates, however, the mixture on some bikes is a little too lean, and the fuel screw being capped with a 1mm-thick plug pressed into a shallow counterbore, prevents access. A typical modification is to drill a hole in and pop out the cap, which allows access to the screw so the low-speed mixture can be adjusted, but then the location of the starter blocks direct access to the screw head. Only the very squat screwdriver tip will fit in the space, and has to be turned by feel, which is not accurate.
One available solution for this problem is an extended screw with a small knurled head, but while into my KLR650 carburetor recently, I discovered a very simple way to extend the screw that is also easier to adjust than the knurled head solution.
FUEL Versus AIR SCREWS
Motorcycle carburetors typically employ a low-speed mixture adjustment via a ‘fuel screw’ or an ‘air screw.’ Opening a fuel screw enriches the low-speed mixture and opening an air screw leans the mixture. How to know which one you have? Air screws are always on the airbox side of the carburetor body, and fuel screws are on the engine side. The KLR screw is on the engine side, thus it is a fuel screw – meaning if you turn it out further, it will richen the mixture.
PROCEDURE
This procedure assumes a high level of experience (every step is not described) and adequate tools. For those less experienced, get help, or approach the work very patiently.
The following photos picture a 2003 model carburetor, but the fuel screw is essentially the same across all the model years.
- Wash the bike to clean all around the carburetor
I suggest cleaning with a pressure washer, with the tank off, so you can get the work area very clean. Plug the fuel and vacuum petcock hoses before washing.
- Remove the carb from the bike carefully
This is not fun on the 650, as the airbox boot is very stiff! Undo the choke cable from the handlebar control so the whole cable assembly stays with the carb! Do not push or pull on the elbow of the choke cable at the carburetor or the plastic part it mates to can snap.
- Mount the carb upside down in a vise. I like to hold it in a vice, squeezed gently but firmly between a rag.
- Liberate the fuel screw from being capped
Use a center drill if you have one. A drill bit can plunge through the 1mm plate and touch the fuel screw and rotate it, losing the factory setting.
- Blow out any chips and put a drop of oil in the threaded bore of the fuel screw
- Count the turns to seat the fuel screw (clockwise) and record the factory setting
My 2003 was 1-3/4 turns out from bottomed.
- Remove the fuel screw
Make sure no chips drop into the hole! You can keep the spring, washer, and o-ring in the hole. Losing the o-ring is very bad because the low speed circuit can suck air through the fuel screw threads.
- Put the fuel screw in a lathe, center drill, then drill .15" deep to diameter .096 (#41 drill), or use a 3/32" drill with some side pressure to get the slightly larger diameter
- With some 3/32" brass rod from a welding supply, make an L-bend part like this:
Note the photo shows all the parts associated with the fuel screw in the correct order of assembly.
- Clock to bent brass rod
Mark the fuel screw head when fully seated (be gentle when bottoming it). I put a scratch in the upper part. You don't have to do this, but it's handy to know your fuel screw setting by position, because you took the time to clock it to, say, the float bowl center, before soldering it.
This is what mine looked like with the fuel screw seated:
- Solder the rod to the fuel screw
Use a liquid flux and lead-based electrical wire solder. You can use a Bernz-type torch, but an electric wire soldering iron works fine. It only takes a very tiny amount of solder! Don’t let solder run onto the threads! If you do, heat the part and blast the melted solder with a quick pulse of compressed air.
Here's the end result on the carburetor:
OTHER DETAILS
When you liberate the fuel screw, you can adjust the low-speed mixture. The KLR650 also tends to run lean in the mid range. One low-cost fix for this is to remove the slide, pull out the needle, and shim under the head of the needle with from .030” to .050” of shims. I typically start with .050”. I try to retain a balance of good fuel economy while getting rid of too-lean carburetion. So far I have not had to spend money on jets or kits, or drill slides or modify slide springs to get a favorable result on the KLR650 and KLR250.
While working on the carburetor, I truncated the idle adjust screw and machined a slot into the new head. The porky knurled head has bugged me for years, so I cut it off. The idle is very stable on the 650, so frequent thumb screw idle adjustments aren’t often needed unless there are major elevation changes in your area. Even then you can compromise with an average idle adjustment and adjust less frequently.
einfahrt is offline   Reply With Quote
Old 08-13-2009, 05:29 PM   #2
spaun
spaun's Avatar
Locale: Southgate,MI.
Postings: 412
spaun is on a distinguished road
Default Re: Improved Fuel Screw Extension
Great idea was wondering how i could fine tune mine without twisting the carb back and forth a zillion times Thanks for the post.
spaun is offline   Reply With Quote
Old 08-15-2009, 10:23 PM   #3
Len P
Len P's Avatar
Locale: Hollywood, Florida
Postings: 645
Len P is on a distinguished road
Great idea.Thanks for posting it.
Len
'06 KLR 650 Red/Silver
Len P is offline   Reply With Quote
Old 09-09-2009, 01:12 PM   #4
grinmachine
grinmachine's Avatar
Super Cool Since: Jul 2009
Locale: guatemala, c.a.
Postings: 454
grinmachine is on a distinguished road
u really should sticky thisª
i was looking for it near the 22cent mod
in how to and procedures!!
klr650a '97
klx650r '94
suzuki rv90 '76
suzuki dr800 '93
grinmachine is offline   Reply With Quote
Old 01-24-2010, 03:48 PM   #5
pub27
Super Cool Since: May 2009
Locale: Ontario
pub27 is on a distinguished road
Hi I was wondering if you could help me, a friend of mine was doing the dynojet mod and accidently drilled out the wrong plug, he drilled out the brass plug behind the pilot plug. I managed to get it out for him but [IMG]file:///C:/Documents%20and%20Settings/Shelley%20and%20Dave/My%20Documents/Dave%27s/float.jpg[/IMG]https://s837.photobucket.com/albums/z...rent=float.jpgI can't seem to find a replacement part number. Any help would be greatly appreciated. Thanks in advance.
pub27 is offline   Reply With Quote
Old 03-04-2010, 01:27 PM   #6
spaun
spaun's Avatar
Postings: 412
Could you make me one of these?
Old 03-04-2010, 01:40 PM   #7
Postings: 9,772
wymanwinn has a spectacular aura aboutwymanwinn has a spectacular aura about
VERY NICE procedure...
thread is now a sticky...
2013 BMW R1200RT...Sassy
2015 BMW S1000R...Duke
2006 KLR685...Critter
1998 Honda VFR800+...Kitty
OR IT COULD COST $1000 or MORE!!! think about it
EagleMike Products (https://www.eaglemike.com)...
Old 03-04-2010, 01:53 PM   #8
Spokane Dave
Spokane Dave's Avatar
Locale: Spokane, Wa
Postings: 1,198
Spokane Dave is on a distinguished road
EXCELLENT write-up Chris (two thumbs up)
Definitely Worthy of being a Sticky and I am sure a lot of guys will appreciate your design / efforts.
Thanks for the contribution !!!!
https://www.klr650.net/forums/showthread.php?t=75394
https://www.klr650.net/forums/showthread.php?t=69972
Spokane Dave is offline   Reply With Quote
Old 03-04-2010, 04:27 PM   #9
XDragRacer
Super Cool Since: Jan 2007
Postings: 4,351
XDragRacer is on a distinguished road
Don't think Mr. Kawasaki considers that particular plug a replacement part; rather, integral to the carburetor body (found no separate illustration in the exploded parts diagram, nor any mention in the accompanying parts list).
I'd look to J-B Welding the plug (if perforated) and reinserting it; don't know if the fuel ("air mixture") screw plug could substitute or not.
Let us know how things work out!
XDragRacer is offline   Reply With Quote
Old 07-19-2010, 12:14 PM   #10
Air2Spare
Air2Spare's Avatar
Super Cool Since: Jan 2009
Locale: Woodstock, GA
Postings: 101
Air2Spare is on a distinguished road
I appreciate the effort put into sharing this well laid out solution...
For those w/ limited time (or less tools), they can pick up the "Extended Fuel Screw for KLR 650 all years (by KoubaLink)" from Happy-Trail for $20... It was a quick install...
Turned the carb, drilled plug w/ hand drill, replaced screw w/ new one.
I even called Happy-Trail and they offered reduced shipping for me since that was the only thing I was purchasing.
Air2Spare is offline   Reply With Quote
Old 07-30-2010, 12:30 AM   #11
richarddacat
richarddacat's Avatar
Locale: tennessee
Postings: 227
richarddacat is on a distinguished road
FYI
https://www.johnsmotorcycleparts.com/...roducts_id=152
05FJR/KLX650c/74R90s
In Texas it is illegal to graffiti someone's Kaw, I mean Cow.
richarddacat is offline   Reply With Quote
Old 07-30-2010, 04:19 AM   #12
thevanrat
thevanrat's Avatar
Locale: 10,000 Lakes
Postings: 1,587
thevanrat is on a distinguished road
Glad that HT and John's sells them already made, my lathe is in the shop (keeping my flux-capacitor and plazma cutter company)
´¯`·.¸¸.·´¯`·.¸ ><((((((º>
New owner of a 2008 Versys!
Previous: 2009 KLR 650 | 31,809 miles
thevanrat is offline   Reply With Quote
Old 07-30-2010, 09:54 AM   #13
Leopard_125
AKA USACelt
Leopard_125's Avatar
Locale: Clovis, SE of Spoonbooty
Postings: 720
Leopard_125 will become famous soon enough
I kinda like the OP's screw looks like one finger will do all the adjusting you need,kinda push the screw to turn.
2002 Green KLR 685,Stage 2,w/Hot Cams
2002 Ducati 944 SS #178
2001 Honda CR125r
2012 Yamaha Super Tenere
Ní uasal aon uasal ach sinne bheith íseal: Éirímis
The great appear great because we are on our knees: Let us rise.
IBA # 34226
IDPA # 35757
Leopard_125 is offline   Reply With Quote
Old 07-30-2010, 10:03 AM   #14
thevanrat
thevanrat's Avatar
Postings: 1,587
Someone should make em and sell em that way. It is a great design. I grew up with access to a full machine shop, and miss being able to do stuff like that. He found a happy medium there by chucking up that little brass fitting and not damaging the threads- I would have ruined it for sure.
I could only picture a three jawed chuck on that right onto the threads.
Brass machines very nice, indeed, but sometimes it can be a bit soft and fragile, if you are chucking on it.
Good job, I'm just sayin. I really miss access to a shop. I farm my projects out now, and find the youngsters in the game have some real talent too, better welders and such than myself!
Find a machinist with a dirt bike, atv and or a snowmobile, and you are in good shape, cause he is no doubt making parts that exceed factory specs for his own toys.
Old 08-05-2010, 11:20 PM   #15
badrocco16v
Super Cool Since: Jul 2010
Locale: Metro Detroit, MI
badrocco16v is on a distinguished road
Excellent idea. I'm doing mine next weekend. Thanks for posting this.
Are there any other ingenious mod's you've come up with?
Curtis
(KLR newb, motorcycle veteran)
badrocco16v is offline   Reply With Quote
Old 08-14-2010, 10:06 PM   #16
shunkjr
shunkjr's Avatar
Locale: West Virginia
Postings: 54
shunkjr is on a distinguished road
great idea!...did mine today...quick and easy mod...took me bout 10 minutes to do...thanks for the idea!!
shunkjr is offline   Reply With Quote
Old 04-03-2011, 06:28 PM   #17
[TASF]Overkill
[TASF]Overkill's Avatar
Locale: Lynchburg, VA
Postings: 505
[TASF]Overkill is on a distinguished road
I bought a small flathead screwdriver bit for one of those crappy multi-tools... You know the kind.
Ground down the flathead bit to make it fit the fuel screw, shortened the whole thing so it would fit in right... now I have a tool to adjust it as I please. :-)
I have one of the thumbscrews, but the damn thing seems to just rattle all the way out. Don't understand!
[TASF]Overkill is offline   Reply With Quote
Old 04-23-2011, 10:04 AM   #18
beakr
beakr's Avatar
Super Cool Since: Mar 2011
Locale: Idaho
Postings: 9
beakr is on a distinguished road
Did mine today, following your procedure - turned out great! Thanks for the idea and for posting it. I drilled the hole slightly deeper - .20" for more surface area for the solder to adhere to. Good job!
beakr is offline   Reply With Quote
Old 04-23-2011, 12:14 PM   #19
Bokrijder
Super Cool Since: Dec 2010
Locale: North East MD
Postings: 468
Bokrijder is on a distinguished road
Unhappy Re: Improved Fuel Screw Extension
Drop that little thing and if the pointy end strikes first - bent !! Ask how I know.
Well that project went South !! -- Happy Trails to the rescue.
Bokrijder
Bokrijder is offline   Reply With Quote
Old 04-23-2011, 01:12 PM   #20
fattkaw
fattkaw's Avatar
Super Cool Since: Feb 2007
Locale: Romeoville Il.
Postings: 487
fattkaw is on a distinguished road
Originally Posted by richarddacat View Post
that would be too easy!!
fattkaw is offline   Reply With Quote
extension, fuel, improved, screw
